Results 1 to 5 of 5
Thread: Spark timing
    Feb 2011
    Default Spark timing
    Hello all. I have 1 quick question. I am running a 3bar cos3 on my rr I need to know what tables to adjust so i have absolutely no timing when i go into boost. I am a noob to tuning so dont hurt me to bad.
    Hi CD, welcome to the forum
    A0010 = boost timing table
    A0010 description says:
    "Once the MAP is above the maximum value allowed in {B0101} "Main VE Table", the PCM will subtract this amount of timing from the final spark advance."
    So whatever timing results from B5913/B5914 (and modifier tables), A0010 then subtracts timing from that.
    Feb 2011
    Ok so in the tables b5913 it is in rpm and grams per cyl. And for the boost timing A0010 table is in map kpa. So my question is how do i know how much to put in the A0010 tables looking at the B5913 tables ?
    Lifetime Member johnv's Avatar
    Jan 2005
    Look at the last columb in B5913 (1.20 grams/cylinder)
    The values you put in the Boost timing table will be subtracted from there.
    so if you are in a cell with 24* timing and you put a value of 10 in the boost timing table across the board you will only see 14* when in boost.
    Back yard boost
    347+ T76 = 770 rwhp 10.96 @ 135 mph
    Feb 2011
    Thank you much.
  1. Questions about spark timing
    By pauly24 in forum Gen IV V8 Specific
    Last Post: June 27th, 2010, 02:13 PM
  2. Help me understand spark timing
    By gpr in forum Gen III V8 Specific
    Last Post: September 16th, 2009, 06:09 AM
  3. Question on 454 Spark Timing
    By N0DIH in forum Vortec V6/V8 Specific
    Last Post: July 14th, 2007, 04:24 AM
  4. logging/scanning timing (spark)
    By Whippled 496 in forum General
    Last Post: November 14th, 2006, 08:11 AM
