The project: 01Z06, mods are vararam CAI, and LG headers. I've got a V1 setup, with an LC-1 wired into the EGR pin on the PCM so I should be able to log it via the OBD2 port. What I'm not sure of is how to setup the calculated PID. In HPT the EGR position can be accessed as PID.2811, can I do the same with EFI or is it named differently?
Next up:
I've read a bit of the big ol Calc VE sticky thread and I think I get it. Using this method with the wide band I should be able to get the fueling pretty close if not right on, no?
How do I go about tackling the ignition tables? That I'm not sure about, especially without a dyno for feedback.
