Results 1 to 3 of 3
Thread: lly tuning issues
    Banned
    Mar 2009
    Default lly tuning issues
    Tunning a buddies truck. I tried reading the stock programming and it came up with a locked pcm error. Tried it again and it read just fine. Built the tune for it and when ahead and licensed his vin to my flashscan. When I go to load the modified tune to his truck it reads the normal attempting to unlock ecm 1 of 4 etc. Well it goes thru all for time and during some of the it pops up something to the effect that it failed the attempt and will try in 1 sec. It says this numerous times then throws and error that will say either something about the bootloader or cannot comunicate with ecm? Any ideas?
    Jan 2006
    did you get it to work?
    Custom Tuning Services
    Dec 2005
    LLY's are a PITA, try removing the radio and info fuse in the engine compartment electrical center, then when you try to read or flash leave the key on for 30 seconds prior to attempting to do anything, have all accessories off, heater if Auto-Climate, dome light over-ride, all doors shut, etc.
    If there is any aftermarket radios, NAV units, I-Pod adapters, they could be causing troubles for you.
    Ross and Paul went to great pain to get the data bus to be quiet but sometimes these LLY's need a little something.
    Good Luck
    www.mscservices.net
  1. Spark tuning issues. Please help
    By Mark300 in forum E37, E38 & E67 PFI ECM's
    Last Post: May 12th, 2010, 09:10 AM
  2. Need help ASAP with tuning issues
    By esco35m in forum General (Petrol, Gas, Ethanol)
    Last Post: February 2nd, 2009, 09:52 AM
  3. Legal issues with tuning
    By Boost in forum Lounge
    Last Post: October 19th, 2007, 07:49 AM
  4. Tuning LLY w/ Nitrous
    By 02gmcwaldoch in forum General (Diesel)
    Last Post: October 10th, 2006, 12:45 PM
  5. When is LLY tuning coming??
    By Redline Motorsports in forum Duramax LLY
    Last Post: January 1st, 2006, 06:24 AM
