Results 1 to 10 of 13
Thread: How to switch from 4l60e to a manual TH400 - 2003 corvette
    Mar 2011
    Default How to switch from 4l60e to a manual TH400 - 2003 corvette
    Computer illiterate but i'm slowly learning. I must have 15 hours in the tutorials and i'm just not getting it (I'm not stupid but i sure feel stupid right now)!! Could someone please help me change the transmission in my tune. I'm assuming i need to change my transmission to a manual setup to turn off the transmission part of my tune. ie: Auto trans (4l60e) to TH400 (not electronic) trans. A step by step to get me to the right part of the tune would be most helpful. The more elementary the steps the better. My tuner lives in another town which is the reason i bought efilive. Thanks so much!
    Mar 2011
    Hello guys, is this not doable or is this so basic i should already know this..... well, i will continue searching to find an answer....any help would be much appreciated. thanks
    Aug 2010
    HelloTracy,
    Initially posting detailed information will often help illicit support from Forum members.
    I’m guessing your 2003 Corvette is using OS 12221588 or OS 12593358. You will need to swap in the Transmission Calibration and Transmission Diagnostics segments from a manual transmission equipped Corvette - using the same OS as your Corvette.
    You will also need to configure some type of useable VSS signal to the PCM.
    Regards,
    Taz
    Jan 2006
    The easiest way I have found is just to full flash it with a6 speed calibration with the same OS, I dont even bother doing the segment swap. You can use the ABS sensor for a VSS signal or when I get TH400's built I get them setup with a electric speed sensor.
    Jun 2008
    Hey Tracy, I understand your frustration We have all been there.
    Go here
    http://www.ls1tech.com/forums/pcm-di...oad-tunes.html
    Find your OS
    study both tunes Copy the files you need to your tune
    I hope that helps
    Best of Luck
    Jorge
    Mar 2011
    Quote Originally Posted by Taz View Post
    HelloTracy,
    Regards,
    Taz
    Quote Originally Posted by minytrker View Post
    Quote Originally Posted by jorge View Post
    Go here
    Find your OS
    I hope that helps
    Best of Luck
    Jorge
    Thanks for the help guys! I will have to chew on the info you provided to figure it out.... I will definately keep my day job! Thanks again, tracy
    Mar 2011
    geoff original.tun
    hello taz, i'm slightly more familiar with efilive than i was a few months ago..... That being said, i would like to try a segment swap that you spoke of. My OS is 02030003 V3 according to my Calibration. I found a tune with the correct OS for the swap..... Can you walk me through or point me in the right direction? Any help would be much appreciated. My tune is attached. Thanks tracy
    p.s...twin turbo 2003 corvette
    HelloTracy,
    Regards,
    Taz
    Hi Tracy,
    Taz is saying to do this: find a manual transmission file for the same OS id and year as your car...
    i.e. find a 2003 Corvette Manual Transmission file that has the same OS id...
    and then perform the segment swap/copy
    [ open target file as calibration, open donor file as alternate, go Edit->Copy Entire Segment and choose the segment;
    this segment gets copied from alternate (donor) file to calibration (target) file;
    then save the calibration (target) file with a new name
    (use the _nnnn incrementing filename feature) ]
    So the trick is finding the same year file with the same OS id...
    if you can't find one, then you have to copy all of your tables to a 12212156 file of the same year/throttle/transmission and proceed from there.
    I'll let Taz add his comments/corrections to what I said.
    HelloTracy,
    Regards,
    Taz
    When you do find a Corvette file with the same OS id, post the target and donor files here (if that's ok with you) so we can make sure they are compatible.
    Mar 2011
    Same OS.tun
    geoff original.tun
    Great info joe! That really doesn't sound too bad from my noob perspective. I listed both tunes, mine (listed as geoff tuner)and the donor. Thanks
  1. stock tune for a manual, 2003 / 2004
    By mrdarreng in forum Duramax LB7
    Last Post: January 22nd, 2010, 08:32 AM
  2. 4L60E Manual Mode Downshifting 3-2 & 2-1
    By TRANNYMAN in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: April 3rd, 2008, 08:11 AM
  3. 4l60e to TH400 car wont go above 2000rpm
    Last Post: October 10th, 2007, 10:00 PM
  4. 4l60e > Th400
    By Macon@MMP in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: January 10th, 2007, 01:07 AM
  5. 2003 corvette IAT ques.
    By Dlong in forum General (Petrol, Gas, Ethanol)
    Last Post: August 18th, 2006, 05:51 AM
