Error report generated by EFILive at 11:17:16 on Dec 29, 2005
Error code: ERR_RESPONSE/5
Response $31: "Request Out of Range".
EFILive Version: 7.3.0 (Build 314)
Platform: Windows XP
Version: 5.1 (build 2600)
Processor type: Pentium 798MHz
Directories
Temporary Cache: C:\Documents and Settings\Eboggs\My Documents\EFILive\V7\Temporary cache
Logged Data: C:\Documents and Settings\Eboggs\My Documents\EFILive\V7\Logged data
Customers: C:\Documents and Settings\Eboggs\My Documents\EFILive\V7\Customers
Configuration: C:\Program Files\EFILive\V7\Configuration
Exported Data: C:\Documents and Settings\Eboggs\My Documents\EFILive\V7\Exported data
Images: C:\Documents and Settings\Eboggs\My Documents\EFILive\V7\Images
Sounds: C:\Documents and Settings\Eboggs\My Documents\EFILive\V7\Sounds
Maps: C:\Documents and Settings\Eboggs\My Documents\EFILive\V7\Maps
Pids: C:\Documents and Settings\Eboggs\My Documents\EFILive\V7\PIDs
Virtual Dash: C:\Documents and Settings\Eboggs\My Documents\EFILive\V7\VDash
Print Reports: C:\Documents and Settings\Eboggs\My Documents\EFILive\V7\Print reports
Bug Reports: C:\Documents and Settings\Eboggs\My Documents\EFILive\V7\Bug reports
Connected: No
Com port: 0
Com setup: EFILive FlashScan FSP: USB
Requested baud rate: 115200
Cable id: 4
Cable code: FlashScan V1
Cable desc: EFILive FlashScan FSP
Cable version: 1.2.17
Cable Firmware date: 20050118
Cable model: FSP
Cable Serial number: 003528284029
Protocols: 0
Protocol list:
Auto connect: No
Scan OBDII info: No
Error retries: 1
Retry delay: 10
Message throttle: 0
Most recently used VIN: 2G1FP22G0W2xxxxxx (Note: 1)
PCM information
PCM HDW Number: 16239740
Calibration ID: 9375621
Serial Number: 0J0RY2724600
Operating System: 19980100
Engine Calibration: Unknown
Engine Diagnostics: Unknown
Transmission Calibration: Unknown
Transmission Diagnostics: Unknown
Fuel System: Unknown
System: Unknown
Speedometer: Unknown
Operating System BCC: Unknown
Stream-Slow scan mode: Supported
Stream-Fast scan mode: Supported
Maximum dynamic packets: 16
Detected modules:
$10="Powertrain Control Module (PCM)"
Selected parameters:
CALC.INJDC1=1,0
CALC.INJDC2=1,2
GM.FTC=1,19
GM.HO2S11=1,4
GM.HO2S12=1,15
GM.HO2S21=1,5
GM.HO2S22=1,16
GM.IAC=1,17
GM.IBPW1=1,6
GM.IBPW2=1,7
GM.INJ1PW=1,18
GM.KR=1,12
GM.TP=1,14
GM.TPS=1,13
SAE.ECT=1,3
SAE.IAT=1,8
SAE.LONGFT1=1,10
SAE.LONGFT2=1,11
SAE.MAP=1,9
SAE.RPM=1,1
SAE.SPARKADV=1,20
SAE.VSS=1,21
Most recent communication with vehicle:
10:57:25.187 Send: $A1,$23,$00,$01,$00,$C5
10:57:25.187 Recv: $B1,$A3,$00,$00,$54
10:57:25.187 Send: $A1,$40,$00,$06,$0C,$6C,$10,$F1,$2A,$00,$8A
10:57:25.203 Recv: $B1,$C0,$00,$05,$6C,$F1,$10,$6A,$00,$4D
10:57:25.203 Send: $A1,$23,$00,$01,$00,$C5
10:57:25.203 Recv: $B1,$A3,$00,$00,$54
10:57:25.203 Send: $A1,$02,$00,$00,$A3
10:57:25.203 Recv: $B1,$82,$00,$04,$46,$53,$50,$00,$20ty of the report.
