Hey guys, having an interesting issue with my LC1 and Im trying to determine if it is my LC1s programming or an issue with my FlashScan.
If you look at the attached logs, you can clearly see that the reported WB AFR is not right. It goes from 4.2-6.38:1 (log1). But what I find interesting is that the reported EQRatio and Lambda values are pretty close to 1:1 (EQ goes .767-1.165:1 [log1]).
Whats going on here, has my LC1 reverted to a weird stoichiometry setting that Im not aware of (trying to determine if I need to buy a USB -> DB9/Serial adapter to program my LC1)?
Running latest everything, fw 2.07.09, V7 b157, V8 b151. Does it in pass thru and BBL on my V2.
Thanks!
