Page 3 of 4 FirstFirst 1234 LastLast
Results 21 to 30 of 31
Thread: graph very slow when im do pass through loging
  1. #21
    Senior Member restless@westnet.com.au's Avatar
    Aug 2008
    tried a new card still the same mesg ?
    it does load the pids and logs fine
    the only time you dont get the mesg is if i use the FAST OPT on the drop down box on the program button
  2. #22
    Blacky said to format the Config space (which resides on V2's internal flash).
  3. #23
    Aug 2008
    i dont know how to RE cofiger it after i for mat it ?
  4. #24
    Oct 2004
    You just load in your options file with the BBX settings and controller selection and then click the 'Program' button.
    Andrew
    EFILive Crew
  5. #25
    Aug 2008
    Quote Originally Posted by Tordne View Post
    were is the opts file bbx and controller selection ?
    oz track set it up originally 2 years ago
    i just do the logging
    thanks
  6. #26
    restless,
    also be sure to update V7 and V8 software from here...
    V8 includes V2 firmware that you flash into V2 using EFILive Explorer (installed with V8).
  8. #28
    Aug 2008
    thanks for the help
    i reformat ed the card in the v2 (instead of the PC) and it now works OK
    i have up dated both V7 and V8 to the latest version and up graded the boot block and firm ware to 2.07.01 and 2.07.09
    ONE question
    WAY doese the v2 display WO2.AFR1 and lambarda and EQ dater wo2 afr2 ect
    when i have AFR only in the setings selected and (PID wo2af1#1)
    theres lots of read outs reagarding afr eq lambarda ect at the bottom of the list on the v2 screen
    afr comanded and wo2afr1 is at the top of the list as per pid list just woundering way im geting all the other stuff is it inter conected
    i have all ways had it since i put the tech2 wide band sensor in
    thanks for help
  9. #29
    With the serial wideband, the V2 reads all the WO2 pids in one go.
  10. #30
    Connect FlashScan, run the V8 EFILive Scan and Tune software, select F6: Devices and then F6: Logging.
    Click on the [Read] button to read the config settings from FlashScan, then check the value of the setting shown in the attached screen shot.
    If necessary, change the setting and click [Program] to program the new settings back into FlashScan.
    You don't need to "save" the settings unless you want to keep a backup copy of the changes on your PC.
  1. Logged info... Graph?
    By spoolinsteve in forum General
    Last Post: April 21st, 2010, 06:53 PM
  2. Loging the TCM? What PID's to use Please?
    By Tarkstoys in forum Allison 5 & 6 Speed
    Last Post: December 9th, 2009, 04:01 PM
  3. stupid question? loging and afr??
    By 1Hotbird in forum Gen III V8 Specific
    Last Post: December 16th, 2007, 03:59 PM
  4. Loging A0009
    By purrvert in forum Custom Operating Systems
    Last Post: April 12th, 2007, 03:24 PM
  5. 50 Dry Shot Graph
    By Beer99C5 in forum Forced Induction and Nitrous Oxide (N20)
    Last Post: October 22nd, 2006, 02:20 PM
