This is probably going to sound like a really dumb question, but if you all knew the background, you would likely understand why my brain has been rendered mostly non functional.
I have a C5 Z06 Corvette that had a custom 427 installed. The guy tuning it right now (He's had the car since September. Prior to that the car was in another shop for 11 months.) Been one problem after another.
The latest problem was a 1514 code, which they were working on Tursday. When I called later in the day to see how things were going, the guy told me that it appeared that the PCM had died. Getting all kinds of odd results, and wouldn't take a new flash correctly, apparently. He said that perhaps the PCM had reached it's useable lifespan for the number of flashes it would take. So a new PCM is on order and will be there on Friday.
That sounds bogus to me, but what the heck do I know? So I'm asking here, is that even remotely possible? If so, how many flashes would it take to reach that point?
Let it be noted that they were pulling the PCM out of the car to program it on a bench. So is it possible the PCM just got zapped somehow?
