Results 1 to 10 of 20
Thread: making a 6.0 swap work - best way?
    Lifetime Member Boost's Avatar
    Dec 2006
    Default making a 6.0 swap work - best way?
    I did not post this in the conversions section because I think it's relatively simple. I am working on a truck that originally had a 5.3 but a cable driven 6.0 (LQ4) was swapped in. The truck is running the original PCM with the 5.3 tune. I would like to flash it with a 6.0 tune. Is it as simple as pulling a cable driven 6.0's tune and flashing it, or will I run into any complications I can't think of right now. Anyone have a stock file for an early LQ4? Thanks!
    8.7 @ 84 (1/8 mile) bolt-ons
    Dec 2006
    Well I downloaded several from Holden Crazy. Even one that is supposed to help with a cable driven swap. I will go from there and keep you posted. Thanks! It has ported heads so I am sure I will be doing a little VE work...
    If you're going from a cable driven 5.3 to a cable 6.0, just grab the same year (99-02 Id use an 02 OS, otherwise 03-07 stick with the same year) 6.0 tune and full flash it.
    I would at minimum do a Calc.VE/AutoVE on it to get the VE table dialed in, spark might need a little adjustment too.
    Dec 2006
    Ok so actually it's the same cable 5.3 throttle body swapped onto the 6.0. Souldn't make any difference right? As long as the rest of the tune is doing it's job. Thanks Erik
    Should work just fine, what year truck is this on? We can probably get a decent baseline tune setup from Holdencrazy.
    Dec 2006
    Yeah thanks it's an '01 and I've already been able to download several files that may be very helpful from HC. Looking good so far. I love this forum / community!
    Im pretty sure you've already found the 01/02 LQ4 tunes that are on there, Id personally use an 02 OS with proper trans segment (60E or 80E). Full flash it then start tuning.
    Dec 2006
    So I am back to working on this. Actually I was considering the one under modified files for an '06 Express that says "may be helpful for swap people with cable throttles". Do you think this is the best one to start with or an '02 LQ4 one?? Either way it's getting full flashed, right? Thanks!
    Aug 2010
    Of Gen III trucks the following is generally true:
    1999 - 2002
    • 512 Kb PCM
    • PCM connectors are Blue & Red
    • PCM "pinouts" are similar (if not the same)
    • use Case Grounded O2 sensors (except 6.0 L engines)
    2003 - 2007 (classic)
    • 1 Mb PCM
    • PCM connectors are Blue & Green
    • use Isolated Grounded O2 sensors (all engines)
    Some 2003 - 2007 Gen III equipped Express / Savana were DBC. All 2003 - 2007 Gen III equipped trucks / SUV were DBW. The benefit of the 2006 Express / Savana tune you downloaded is the option of a DBC 2003 - 2007 swap.
    I would not recommend trying to swap a 1Mb PCM into a 2001 truck, or trying to run an Express / Savana tune in an OEM truck application.
    Regards,
    Taz
    Lifetime Member Mr. P.'s Avatar
    May 2007
    What exactly are you doing?? what year is the truck? is it originally a DBW or cable TB vehicle? (I understand the LQ4 is a manual/cable TB)
    Easiest way is to continue using the same type of throttle body that was originally equipped on the vehicle. In other words, if the 5.3 came with a cable-type TB, then continue using that on the replacement motor; else if the original 5.3 came with a drive-by-wire TB, then the replacement motor should use a DBW. OR, you will have to do a cable-to-DBW swap, or vice versa.
    Mr. P.
  1. e38 4l80 swap 07 silverado cant get speedo to work???
    By b18cls1 in forum E37, E38 & E67 PFI ECM's
    Last Post: July 6th, 2010, 02:45 AM
  2. Making PIDS
    By minytrker in forum General
    Last Post: October 16th, 2009, 05:13 AM
  3. pcm swap any 411 will work?
    Last Post: May 25th, 2009, 11:30 PM
  4. scanner buttons work work?
    By pullincrazy88 in forum FlashScan V2
    Last Post: May 16th, 2009, 01:12 PM
  5. Making Scripts.
    By 5.7ute in forum Tips and tricks
    Last Post: September 12th, 2007, 10:30 AM
