Results 1 to 5 of 5
Thread: The dreaded 03 lb7 ecm crash! Ross Cindy?
    Sep 2007
    Default The dreaded 03 lb7 ecm crash! Ross Cindy?
    Well I was trying to help a friend by loading a tow tune in his 03 lb7. After getting the ECM Locked prompt multiple times when trying to download his stock file I was finally able to get it to download. Knowing the history of these bastard corrupt ecm's after being reflashed by the dealer i was kind of skeptical of moving foward with tuning his truck, but did so any way. So I went ahead and married the liscense to his vin and started uploading the tow tune. 5K Megabytes into the upload it locked up on me saying it was trying to reconnect to the ecm. After 3 hours of letting it try to reconnect I gave up. I tried to load the tune in again, and all I get is Bootloader rejected. Truck won't start/turn over. I figured the Pass Lock/VATS was causing this, so I tried to relearn that. No worky.
    I have another 03 ecm, and was wondering if I use a Tech 2 can I load the proper tune in it by using his VIN? I know I'll have to marry the ecm to the bcm using the VATS relearn.
    2004 GMC CC D-Max
    EFI,Tranny,and a couple other goodies.
    Nov 2009
    Have you tried to FULL FLASH the stock file back in? This is done by the SECOND red arrow next to the "cal flash" (first) red arrow...
    -Kory
    http://www.PPEI.com/
    Sep 2007
    Oh yeah. I get the big red square. BOOTLOADER REJECTED. I'm going to pull his ecm and put it in my truck and try to load it again. He has an aftermarket Satelite radio in his. I pulled all the fuses but was told that if it has an inline harness that pulling fuses won't work.
    2004 GMC CC D-Max
    Batteries getting low?
    I have your ECM's in stock if you need another.
    Custom Tuning Services
    Make sure you're using the latest software available here: http://www.efilive.com/index.php?opt...=48&Itemid=133
    I recommend saving the *.tun file as a *.ctd file using the EFILive V7.5 Tune Tool software, then use the V8 EFILive Scan And Tune software to flash the controller. The V8 flash routines are better than the V7.5 flash routines.
  1. LB7 ECM Read issues
    By Cougar281 in forum Duramax LB7
    Last Post: November 17th, 2011, 02:20 PM
  2. Can't connect to LB7 ecm
    By madmatt in forum Duramax LB7
    Last Post: May 5th, 2011, 01:31 AM
  3. Cannot connect to lb7 ecm but can tcm
    By blewgrassmotorsports in forum Duramax LB7
    Last Post: February 11th, 2011, 04:04 PM
  4. Dreaded knock.... cant seem to get my tune right
    By Dopey in forum Gen III V8 Specific
    Last Post: June 4th, 2010, 08:12 AM
  5. HELP! ECM Crash
    By a78turbo in forum Duramax LLY
    Last Post: March 20th, 2006, 02:03 AM
