Standalone harness & ECM(E38)
I just flashed a 2008 1500 L76 6.0ltr 4L70E 0S(12617631) into a E38 that originally came in a 2008 3500HD Silverado LY6 6.0ltr 6L90E OS(12622142)...Everything is fine at start-up....Motor turns on, revs but when I go to move the vehicle, it goes into some sort of Limp mode and accelerator pedal will not work and motor just idle's no matter what I do!!! I check DTC's and it shows dtc's for cooling fan & Malfunction indicator light(easy fix)....But other times it will show **Camshaft Position Sensor BANK1 & BANK2 fault***
Any ideas? Maybe I should have used a E38 from the same type of 1500 Silverado?
