Page 6 of 16 FirstFirst ... 45678 ... LastLast
Results 51 to 60 of 158
Thread: Problem with my Head/Cam 98 LS1 camaro - files attached
  1. #51
    Jul 2008
    Josh, something seems amiss with your LTFT's. In some places adding +23% to your MAF did nothing..
    Well try the following:
    1. Make B0120 400 RPM instead of 4000.
    2. Drop SAE.SPARKADV Pid.
    3. Drop SAE.VSS Pid
    3. Add GM.HO2S11 and GM.HOS21 Pids
    4. Add GM.IBPW1 Pids.
    You should still be at 24 channels or less.
    Whenever you are adding that much Airflow to the MAF, normally you see a 1:1 increase in Trim change. +23% = a 23% drop in LTFT's. So, if you do not see that you always worry about 4 things.
    1. NB O2 sensors are not switching properly.
    2. You're injector flow is not supporting your Mods.
    3. Big-time exhaust leak..usually this is the culprit.
    4. MAF needs cleaning (are you de-screened..is this a stock MAF?)
    Re-set your Trims again..if you really had done this you should have started out at (0) on your Trims. Looks like you were still at +25% when your log started...
    Sorry for the hassle, but these changes are necessary..
  2. #52
    Jul 2008
    Josh, also reset your trims using the following:
    With key on (ignition)..
    Calibration >> Long term Fuel Cells>> Reset both banks. The Table should now read all zeros. So, when you start logging the LTFT's should not already have a value.
    I'm thinking yours did not re-set..you seemed to get richer during the log as your LTFT's learned..
  3. #53
    Apr 2011
    I made the change to B0120 and set it from 4000 to 400.
    Droped SAE.SPARKADV Pid and SAE.VSS Pid
    Already had GM.HO2S11 so I added GM.HOS21 and GM.IBPW1 Pids. I now have 19 PIDS Selected.
    OK DESCRIPTION CAPTION UNITS SYSTEM CH PARAMETER
    Y Absolute Throttle Position TP % Throttle 1 SAE.TP
    Y Air Flow Rate From Mass Air Flow Sensor MAF Grams/s,Lbs/Min Air 2 SAE.MAF
    Y Air Mass Per Cylinder CYLAIR Grams/cyl Air 0 CALC.CYLAIR
    Y Commanded Air Fuel Ratio AFR :1 Fuel 2 GM.AFR
    Y Engine Coolant Temperature ECT °C,°F Temperature 1 SAE.ECT
    Y Engine RPM RPM RPM Conditions 2 SAE.RPM
    Y Fuel System FUELSYS Fuel 2 SAE.FUELSYS
    Y Heated O2 Sensor Voltage Bank 1 - Sensor 1 HO2S11 mV O2 1 GM.HO2S11
    Y Heated O2 Sensor Voltage Bank 1 - Sensor 2 HO2S12 mV O2 1 GM.HO2S12
    Y Heated O2 Sensor Voltage Bank 2 - Sensor 1 HO2S21 mV O2 1 GM.HO2S21
    Y Injector Base Pulse Width Bank 1 IBPW1 ms Fuel 2 GM.IBPW1
    Y Injector Base Pulse Width Bank 2 IBPW2 ms Fuel 2 GM.IBPW2
    Y Injector Duty Cycle Bank 1 INJDC1 % Fuel 0 CALC.INJDC1
    Y Injector Duty Cycle Bank 2 INJDC2 % Fuel 0 CALC.INJDC2
    Y Intake Air Temperature IAT °C,°F Temperature 1 SAE.IAT
    Y Intake Manifold Absolute Pressure MAP kPa,PSI Air 1 SAE.MAP
    Y Long Term Fuel Trim - Bank 1 LONGFT1 % Fuel 1 SAE.LONGFT1
    Y Long Term Fuel Trim - Bank 2 LONGFT2 % Fuel 1 SAE.LONGFT2
    Y Retard Due to Knock KR Degrees Spark 1 GM.KR
    MAF is stock but descreened.
    Also have stock injectors.]
    Also make sure the fuel trims are cleared using both methods before I get logs tomorrow with the new PIDS.
    I will clean the MAF in the morning and check everything for exhaust leaks. Also will put in my new bosch 02 sensor for my innovate wideband and get some logs from it to compare. Once the LC1 > Scanv2 serial comes In I can integrate that.
  4. #54
    Jul 2008
    To evaluate your CALC.VET Tune & Log, we need to see EXACTLY the Pids as indicated in the following screen-shot.
    Total 23 channels. No substitutions please..
  5. #55
    Apr 2011
    I have 23 PIDS selected. My tuning laptop is small so I could not fit them all in one screen. So I attached them in two images.
    Its nice out today, so I'm going to go clear the fuel trims and get another log. Everytime I reset the fuel trims it doesnt want to idle until it gets a little heat in the motor.
Name:	VNET CALC PIDS 2.png
ID:	10667   Click image for larger version.
Name:	VNET CALC PIDS 1.png
  6. #56
    Apr 2011
    I went back and double checked, and I still had the first set of PIDS selected. So I removed VSS, Cyl1 Timing as mentioned earlier.
    Also selected
    Heated 02 Sensor Voltage Bank 1- Sensor 1
    Heated 02 Sensor Voltage Bank 1- Sensor 2
    However, the three of those have red X's on them. I'm going out to the car to see if I can validate them???
Name:	New CALC PIDS v1.png
  7. #57
    See at bottom of PIDs tab it says Selected Channels... you can go up to 24 (don't exceed 24, otherwise the frame rate slows down).
  8. #58
    Apr 2011
    Just attached Flashscan to the car and it validated all the PIDS we needed. I now have 24 selected.
    Also uploaded new tune with B0120 400 RPM instead of 4000.
    Going to clear the fuel trims and get some more logs.
  9. #59
    Apr 2011
    Reset fuel trims and they al are at 0%. Going to let the car warm up and go log now.
Name:	reset fuel trims.png
  10. #60
    Apr 2011
    Just got back making a new log w/ the updated PIDS and made sure fuel trims were reset.
    How does this look now?
  1. boosted 2010 Camaro files
    By general23cmp in forum E37, E38 & E67 PFI ECM's
    Last Post: September 18th, 2009, 05:27 AM
  2. Cam I Tune A 97 lt1 camaro with efi live
    By Adam Calley in forum General (Petrol, Gas, Ethanol)
    Last Post: January 12th, 2009, 05:22 AM
  3. BIG Auto VE problem - Tune files attached
    By Kevin Doe in forum General (Petrol, Gas, Ethanol)
    Last Post: October 14th, 2007, 02:57 PM
  4. 2000 Camaro Head and cam tune file.
    By DaddySS in forum General (Petrol, Gas, Ethanol)
    Last Post: April 12th, 2007, 11:10 AM
  5. A question for you head and cam guys.
    By johnsZ06 in forum General (Petrol, Gas, Ethanol)
    Last Post: April 12th, 2006, 07:12 AM
