Results 1 to 10 of 20
Thread: Fuel Trims/Learning will not disable
    Sep 2010
    Default Fuel Trims/Learning will not disable
    Working on a 2002 LS2 based Corvette
    GENIII LS PCM
    I have forced it into OL, turned off all the STFT and LTFT stuff and it still wants to make STFT corrections. When I use the DVT to force into OL and disable learning it works for a bit then starts learning and making corrections all over again..
    Paul Meister
    EFI Calibrator/Managing Member, Torq Speedlab, LLC
    Specializing in late model Ford, GM and Dodge EFI Calibrations
    SCT, EFI Live, HP Tuners, FAST, BS3 and much much more
    Jun 2005
    Tune file?
    Sep 2010
    How do I attach a file here?
    Paul Meister
    At the bottom where it says Post Quick Reply and Go Advanced, click Go Advanced. Type your post, then scroll down to Additional Options. There will be a button labeled Manage Attachments, click it then Add Files in the upper Right. Click Select Files, select the ones you want, then click OK then Upload Files. Click Done then you'll be back at the main posting page, click Submit. Should be set!
    (Sorry if its a little wordy)
    Is B4206 disabled...?
    Sep 2010
    Does not exist
    Paul Meister
    Sep 2010
    Here is the latest working calibration. Another annoying issue I am having with the maf failed is on startup, the maf does not "fail" right away and the car runs like crap. Once it fails (I can see it when my CEL comes on) it purrs like a kitten
    With the cam in the car I do not want any fuel correction right now (or ever at idle)....especially when tuning. Once it is done, I do not mind having some adjustment during cruise
    ScottRoss_02Vette_A&ABlower_ZR1MAPSensor_FASTIntake_60lbInjectors_KooksLT0008.tun
    Paul Meister
    Hi Paul,
    COS's have B3647 instead of B3605 and B4206...
    for any cell in B3647 set to stoich AFR, the PCM will trim using STFT.
    this is a feature (SOL = semi open loop);
    Sep 2010
    COS has B3647 instead of B3605 and B4206...
    This is already set and done. I do not want any trims at idle. Cam is too big thus resulting in a false lean condition at idle and its all over the place. I use the DVT to kill fuel trims and force back into OL but it only lasts for a few minutes
    I need to kill all learning/trims and keep it in OL.
    Paul Meister
    All those lambda 1.00 cells will trim using STFT.
  1. Tuning with fuel trims
    By 68problemchild in forum Gen IV V8 Specific
    Last Post: July 30th, 2011, 08:43 PM
  2. E38 fuel trims
    By minytrker in forum Gen IV V8 Specific
    Last Post: July 2nd, 2010, 02:44 PM
  3. How to disable fuel trims to adjust MAF
    By sdhager in forum Gen III V8 Specific
    Last Post: May 1st, 2009, 08:01 AM
  4. Disable adaptive shift learning after Shift Kit Install
    By BlackGMC in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: January 24th, 2008, 05:49 AM
  5. Fuel Trims are 0
    By Rhino79 in forum General (Petrol, Gas, Ethanol)
    Last Post: January 17th, 2007, 04:15 PM
