Page 2 of 2 FirstFirst 12
Results 11 to 20 of 20
Thread: Fuel Trims/Learning will not disable
    i.e. I'm saying you have to set those cells to Lambda 0.99 or 1.01 to avoid SOL/STFT.
    Sep 2010
    All those lambda 1.00 cells will trim using STFT.
    This is a commanded AFR table. I am wanting it at 1 right now while tuning and with all STFT and LTFT off it should not correct. My VE should be adjusted to get it to 1
    Paul Meister
    EFI Calibrator/Managing Member, Torq Speedlab, LLC
    Specializing in late model Ford, GM and Dodge EFI Calibrations
    SCT, EFI Live, HP Tuners, FAST, BS3 and much much more
    That is what I am saying... the COS will trim on B3647 cells that are 1.00.
    If the COS hits a cell in B3647 that is 1.00, the COS will trim to 1.00 using STFT.
    This is a feature of the COS's.
    Default Btw:
    If you set it to command 0.99 lambda, and your wideband measures 0.99 lambda, the BEN will be 1.00 and VE is good.
    i.e. you should be adjusting the VE to make BEN converge on 1.00 regardless of what is being commanded.
    If you notice, the COS does not have B4206 (enable/disable STFT on 1.00 cells in OL table)...
    the OL table cell value being 1.00 enables STFT trimming on it.
    Sep 2010
    Ok, so if I set this to .99 or something else other than 1.0 it will disable trimming?
    Paul Meister
    Quote Originally Posted by Meister View Post
    Yes, that is correct.
    Sep 2010
    Interesting and exactly what I want. Trim off idle and cruise, no trims at idle and wot. Fantastic
    Now, if I could only figure out why when I first start the car the maf is not failed (CEL is OFF), it runs poorly for a few seconds until CEL kicks on (indicating maf is failed)....the maf wire is removed from the harness
    Paul Meister
  9. #19
    Does C6001 have the MAF DTC's set to 1-Trip...?
  10. #20
    Sep 2010
    Yes these were set properly along with 101, 102, and 103 to tell me the MAF has been failed (which I turn off to deliver the car).....9 out of 10 times it happens where the CEL would not come on, it would run poorly and then once the CEL comes on it would be perfect. That 1 time, which I cannot attribute to any condition, it is perfect
    Paul Meister
  1. Tuning with fuel trims
    By 68problemchild in forum Gen IV V8 Specific
    Last Post: July 30th, 2011, 08:43 PM
  2. E38 fuel trims
    By minytrker in forum Gen IV V8 Specific
    Last Post: July 2nd, 2010, 02:44 PM
  3. How to disable fuel trims to adjust MAF
    By sdhager in forum Gen III V8 Specific
    Last Post: May 1st, 2009, 08:01 AM
  4. Disable adaptive shift learning after Shift Kit Install
    By BlackGMC in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: January 24th, 2008, 05:49 AM
  5. Fuel Trims are 0
    By Rhino79 in forum General (Petrol, Gas, Ethanol)
    Last Post: January 17th, 2007, 04:15 PM
