Results 1 to 4 of 4
Thread: commanded afr
    Dec 2005
    Default commanded afr
    hi i have a 8.1 with stock tune was looking at the commanded afr at wot was still 14.68 does command lower warming up on cold starts even at low speeds thanks
    Oct 2004
    There are a number of triggers for PE mode which is what will enable and lower the commanded AFR. On one stock truck tune I saw the PE delay {B3608} was 60 seconds. Would be worth checking that to start with.
    Andrew
    EFILive Crew
    Jan 2004
    Quote Originally Posted by Tordne
    There are a number of triggers for PE mode which is will enable and lower the commanded AFR. On one stock truck tune I saw the PE delay {B3608} was 60 seconds. Would be worth checking that to start with.
    Yup saw the same thing here.
    Quote Originally Posted by 69camaro5speed
    One of our Beta testers ealry on found he was running 14.63 at full throttle, I didn't believe it until I saw the tune.
    Change B3608 to cure the problem.
  1. “Un-commanded” AFR at WOT
    By Rontune in forum Gen III V8 Specific
    Last Post: July 3rd, 2009, 02:58 PM
  2. Whacked Commanded AFR?
    By N0DIH in forum Gen III V8 Specific
    Last Post: November 10th, 2008, 05:47 PM
  3. commanded air fuel
    By 69camaro5speed in forum General
    Last Post: March 11th, 2007, 12:37 PM
  4. Commanded AFR not a valid PID?
    By Rocketman69 in forum Vortec V6/V8 Specific
    Last Post: February 15th, 2007, 01:10 AM
