Tried a few more things to eliminate some possibilities.
- Changed plugs from platinums to coppers (heat range 6) to ensure plugs weren't causing the knock
Log here shows a run after the plug change. Log_P15RSX_0020newplugs.efi Same situation as before
- Pulled 3 degrees across the timing map (map already quite retarded)
Log here shoes a run after the timing change. Log_P15RSX_0021newplugslowtiming.efi Same situation
Unless something else in the cylinder is getting a hot spot. Thinking false knock.
Joe, out of interest, what makes you say it doesn't look like real knock.
If it is false I guess its likely a resonance thing that something is rattling around those load areas.
