Ok so my LLY was running fine but I had to up load my tow tune. So as usual I plugged my V2 in and started the process... like half way through it said it couldnt complete it and I did the whole the whole 15 sec thing and tried again. Now it says bootloader rejected cause no response from the ecm. I've tried no high speed and alternate keys and I've tried to read current pcm callibrations and I also tried to do a full reflash with my stock tune. I waited all night and most of today to try it again. This is what I get when I try to do just a cal flash.
14:51:29.932: Scanning for EFILive FlashScan V2 HAPI
14:51:29.948: Autodetect interface ...
14:51:30.229: Interface firmware version: 2.7.3
14:51:30.229: Connection to [FSV2] interface is OK
14:51:30.260: CAN-VPW Bridge Activated
14:51:30.322: Current protocol set to: "SAE J1850 VPW"
14:51:30.322: Autodetect PCM...
14:51:31.648: PCM not detected.
14:51:31.648: Autodetect ECM...
14:51:32.709: ECM not detected.
14:51:32.709: Autodetect TCM...
14:51:32.740: Connection to TCM is OK
14:51:32.771: Current protocol: "SAE J1850 VPW"
14:51:33.021: Interface firmware model: FSV2
14:51:33.037: Interface firmware version: 2.7.3
14:51:33.052: Interface firmware date: Nov 22, 2010
14:51:33.083: FlashScan serial number: 003847607017
14:51:33.115: FlashScan license number: 003847607017
14:51:33.973: Getting status...
14:51:38.122: Getting status, attempt 2 of 10...
14:51:39.183: Getting status, attempt 3 of 10...
14:51:40.244: Getting status, attempt 4 of 10...
14:51:41.305: Getting status, attempt 5 of 10...
14:51:42.350: Getting status, attempt 6 of 10...
14:51:43.411: Getting status, attempt 7 of 10...
14:51:44.378: Getting status, attempt 8 of 10...
14:51:45.345: Getting status, attempt 9 of 10...
14:51:46.390: Getting status, attempt 10 of 10...
14:51:47.451: Status: Unknown.
14:51:52.162: Disconnecting ...
14:51:52.771: CAN-VPW Bridge Deactivated
14:51:52.786: Disconnected
14:51:53.457: Scanning for EFILive FlashScan V2 HAPI
14:51:53.473: Autodetect interface ...
14:51:53.753: Interface firmware version: 2.7.3
14:51:53.769: Connection to [FSV2] interface is OK
14:51:54.019: Interface firmware model: FSV2
14:51:54.034: Interface firmware version: 2.7.3
14:51:54.065: Interface firmware date: Nov 22, 2010
14:51:54.081: FlashScan serial number: 003847607017
14:51:54.112: FlashScan license number: 003847607017
14:51:54.128: Disconnecting ...
14:51:54.736: CAN-VPW Bridge Deactivated
14:51:54.752: Disconnected
14:51:55.423: Scanning for EFILive FlashScan V2 HAPI
14:51:55.438: Autodetect interface ...
14:51:55.703: Interface firmware version: 2.7.3
14:51:55.719: Connection to [FSV2] interface is OK
14:51:55.735: CAN-VPW Bridge Activated
14:51:55.813: Current protocol set to: "SAE J1850 VPW"
14:51:55.813: Autodetect PCM...
14:51:56.889: PCM not detected.
14:51:56.889: Autodetect ECM...
14:51:57.934: ECM not detected.
14:51:57.934: Autodetect TCM...
14:51:57.981: Connection to TCM is OK
14:51:58.012: Current protocol: "SAE J1850 VPW"
14:51:58.262: Interface firmware model: FSV2
14:51:58.277: Interface firmware version: 2.7.3
14:51:58.309: Interface firmware date: Nov 22, 2010
14:51:58.340: FlashScan serial number: 003847607017
14:51:58.371: FlashScan license number: 003847607017
14:51:59.198: Getting status...
14:52:03.347: Getting status, attempt 2 of 10...
14:52:04.393: Getting status, attempt 3 of 10...
14:52:05.453: Getting status, attempt 4 of 10...
14:52:06.499: Getting status, attempt 5 of 10...
14:52:07.559: Getting status, attempt 6 of 10...
14:52:08.620: Getting status, attempt 7 of 10...
14:52:09.665: Getting status, attempt 8 of 10...
14:52:10.289: Getting status, attempt 9 of 10...
14:52:11.350: Getting status, attempt 10 of 10...
14:52:12.395: Status: Unknown.
14:52:13.347: Bootloader version: DLLY_v1.4C (06F0-035F)
14:52:13.347: Preparing ECM for reflash...
14:52:15.422: Autodetect interface ...
14:52:15.687: Interface firmware version: 2.7.3
14:52:15.687: Connection to [FSV2] interface is OK
14:52:15.687: Autodetect PCM...
14:52:17.762: PCM not detected.
14:52:18.791: ECM may not be secured - did not reply to seed request
14:52:18.791: Initializing ECM...
14:52:18.791: Initializing ECM, step 1 of 4
14:52:18.807: Initializing ECM, step 2 of 4
14:52:18.807: Initializing ECM, step 3 of 4
14:52:18.807: Initializing ECM, step 4 of 4
14:52:23.830: No response from ECM. Retry 1...
14:52:25.983: Autodetect interface ...
14:52:26.248: Interface firmware version: 2.7.3
14:52:26.248: Connection to [FSV2] interface is OK
14:52:26.264: Autodetect PCM...
14:52:28.307: PCM not detected.
14:52:29.337: ECM may not be secured - did not reply to seed request
14:52:29.337: Initializing ECM...
14:52:29.337: Initializing ECM, step 1 of 4
14:52:29.353: Initializing ECM, step 2 of 4
14:52:29.353: Initializing ECM, step 3 of 4
14:52:29.353: Initializing ECM, step 4 of 4
14:52:34.376: No response from ECM. Retry 2...
14:52:36.733: ECM is in an unknown state.
14:52:39.120: Disconnecting ...
14:52:39.728: CAN-VPW Bridge Deactivated
14:52:39.744: Disconnected
14:52:39.744: Data transfer was interrupted.
14:52:43.443: Done!
Any and all help is appreciated
