Results 1 to 10 of 11
Thread: tuning e67
    Nov 2010
    Default tuning e67
    i have read the how to tune made by swingtan and it is a good one , but i want to do the tuning in lamba and eq so that being said. i think my pids should be commanded eq
    wide band lamba instead of commanded afr and wide band afr.
    it that is so what other info should i read before i start this.. so i know what to do
    thanks for the help
    donald
    Your BEN correction factor will now be (commanded eq) * (wideband lambda).
    See the attached calc_pids.txt as an example (serial wideband).
    All else is same as Swingtan's tutorial.
    Nov 2010
    thanks joecar
    donald
    Nov 2010
    ok what files do i need to read and understand to make this pid or what to do cause i am being really thick headed on this cant seem to find what i need to know
    donald
    Oh, I should have also said this:
    copy that calc_pids.txt file to this folder: My Documents\EFILive\V7.5\User Configuration
    and then start the scantool, goto the PIDs tab, click on the Parameter column heading (to sort on this col) and look down that col, you will see the pid CALC.WO2BEN;
    that pid requires that GM.EQIVRATIO be selected; let me know if this pid doesn't work on the E67 (it should).
    Nov 2010
    ok nether of the pids calc.wo2ben or gm.eqivatio work they are not for a e67 it says has red cross through them
    donald
    Ok, it seems E67 uses E67.AFRATIO, use this instead of GM.EQIVRATIO.
    On your V2, use S&T enable automatic logging of serial/digital pids (i.e. EXT.WO2AFR)...
    In the calc_pids.txt your BEN would be EXT.WO2AFR / E67.AFRATIO.
    Nov 2010
    ok joe i went into the calc_pids.txt and changed it to EXT.WO2AFR / E67.AFRATIO but i noi matter where i look on the v2 can i find enable automatic logging
    thanks for you help and i know it is hard to belive lol but i an't all the time this dumb
    donald
    Nov 2010
    i have chossen wo2afr and e67.afr ratio to log . dose this mean i am working in afr instead of lamba and eq
    donald
    Donald, see attached pic.
  1. Unknown E67
    By Lennart in forum E37, E38 & E67 PFI ECM's
    Last Post: January 16th, 2011, 11:24 AM
  2. E67 with 12611951
    By modpcm in forum E37, E38 & E67 PFI ECM's
    Last Post: June 8th, 2009, 03:23 PM
  3. E67 T42 tuning questions, facts, myths.
    By TBMSport in forum E37, E38 & E67 PFI ECM's
    Last Post: June 6th, 2009, 04:22 AM
  4. E67 cts-v
    By jbehe in forum E37, E38 & E67 PFI ECM's
    Last Post: May 24th, 2009, 11:59 PM
