Page 1 of 3 123 LastLast
Results 1 to 10 of 25
Thread: 3.0 liter sidi poor fuel mileage
Hybrid View
    Nov 2010
    Default 3.0 liter sidi poor fuel mileage
    Anybody have any suggestions on trying to get the fuel mileage up on a 2010 Terrain with 3.0 liter sidi. You would think with all the tech. in this engine it should be able to get more than 20 mpgs. I have the v2 flash and tune. I am new to this whole tuning thing so I apologize for my ignorance.
    Jul 2007
    There is no tuning support for the V6 yet, so it's going to come down to...
    • How the car is used.
    • The fuel being used.
    • Driving style
    You may be able to adjust the auto settings though and that can help with mileage.
    Simon.
    Actually Simon, we do support the 3.0L and 2.4L SIDI as used in the Terrain, it uses an E39 ECM.
    Redonetoo, I think the problem comes down to the weight of the vehicle, getting all that mass moving with a small engine takes a lot of effort. If the Terrain has an instant MPG readout take a look when you take off from the lights. I've only just started playing around with the 3.0L V6, but so far the fuel economy is about on par with what I thought it would be (11.5 L/100), which is about 20MPG. I would expect about 26-27 MPG on the highway.
    Nov 2010
    Default Poor fuel mileage
    I am looking at the short term fuel trims and they seem to always stay in they negative. Also the o2 sensors seem to run constantly around .750 volts. Which makes me think it is rich. I have changed the gear ratio in the transmission to 3.39 to help with the weight factor. Just in my mind it makes no sense that an engine of this size gets close to the same mileage as a v-8. I had a 2000 5.3 in a full size truck that got 18.
    Nov 2010
    It does have the instant mpg feature. And you are right it does seem to drop quickly. But even at light acceleration on the highway it drops hard. I thought the advantage of the sidi was to more accuratlely control fuel timing. They have the injection timing at 300 degrees or so before tdc. So how is this better than MFI? I was told I could play with the MAF settings to help with the running rich. Like I said I am new to this.
    Nov 2010
    This car has never seen 26 mpg. I went to Greenville NC from raleigh the other day all interstate 19.5 mpg. After I reset the trip.
    Jul 2007
    Ahh, yes... I missed the E39 bit there
    Some logs of the car would help, it would help shown the longer term details of what the fueling is doing, if it included wide-band O2 data it would be even better. Also, a copy of the tune file to see what may be possible.
    The MAF its self does not make any "adjustments" to any thing. The MAF is just a sensor, it measures air flow / density and reports that back to the ECM. If it's faulty (broken or even just dirty) it will report the wrong values and the ECM will try and correct when in Closed Loop (CL) mode. If the ECM can't correct, it should throw and error code.
    STFT's should not remain negative, they should oscillate +ve and -Ve. LTFT's can remain either +ve or -ve though. If the NB O2's are stuck at 750mV and do not oscillate at all, then I'd say the closed loop function is just not working, and the car is always running rich. So it's probably worth doing the following...
    • checking for any error codes before trying anything else.
    • Log the car ensuring STFT's, LTFT's and O2 mV are being logged. Also the Fuel Mode (OL vs CL) should be logged as well as ECT.
    • Clean the MAF, use a "carby cleaner" to rinse off the sensor elements inside the MAF.
    It sounds like it's stuck in OL mode and simply running too rich. This might be due to a faulty O2 sensor or even a stuck thermostat not letting the car warm up correctly.
    Simon
    Again, it's how hard the 3.0L needs to work to get the vehicle moving, a 6.0L GenIV will move a 2 tonne vehicle away from the lights with ease, maybe shift at 2,200RPM at moderate throttle. Your 3.0L has to work twice as hard as the 6.0L, rev a little harder etc, if it's working hard it's got to use more fuel. At speed the 3.0L should do pretty good though.
    SIDI allows them to have far higher compression, the LF1 is up at 11.7:1 from memory, that's race gas levels from days gone by. Injection timing is probably not something you want to 'experiment' with, GM would have spent a long time getting that timing right.
    Nov 2010
    Even at idle the o2 sensors are running close to.750 is this normal? I live in Eastern North Carolina flat land. And most of her driving is interstate 75 to 80 mph. We had a Mariner it got 26 mpgs average with a 3.0 liter. The Terrain is much heavier. I just don't see the advantage of the sidi.
    Nov 2010
    I work on Diesel truck engines. We can advance and retard injection timing at different rpms to get better performance. But if not careful you can melt a piston. I was just amazed at the time at which they were injecting fuel. The are injecting on the intake stroke instead of on compression stroke. I guess with gasoline that would be impossible.
  1. lb7 fuel mileage
    By erisk71 in forum Duramax LB7
    Last Post: April 12th, 2011, 04:16 PM
  2. Tahoe poor mileage - help please
    By Boost in forum Gen IV V8 Specific
    Last Post: January 18th, 2011, 12:43 AM
  3. 2010 Terrain 3.0 sidi
    By redonetoo in forum E39, E80, E82 & E92 SIDI ECM's
    Last Post: November 25th, 2010, 02:21 PM
  4. poor mileage :(
    By Boost in forum Gen III V8 Specific
    Last Post: July 12th, 2010, 02:17 PM
  5. 2005 LLY Fuel mileage
    By dieknow in forum Duramax LLY
    Last Post: February 7th, 2006, 05:54 PM
