Results 1 to 5 of 5
Thread: No closed loop
    Jan 2008
    Default No closed loop
    all
    i am trying to return to closed loop but having troubles.
    please have a look at the file and log,
    also, i only have 1 02 sensor plugged in, but dont see an error or anything in the scan tool, could this be an issue,
    how do i disable 1 02 bank?
    and could this cause trim problems as it thinks it for 1 bank only
    can this be changed
    VX Commodore Turbo Intercooled - GT4294 - 60lB injectors - 3K stall
    Jan 2008
    log
    Jan 2008
    hi all
    anyone with suggestions?
    Cheers
    Hi Fezz,
    You need the front NBO2's for both banks (EFILive can't disable one bank), and you need the DTC's for them enabled.
    Jan 2008
    thanks, i will need to extend the loom as i have a single exhaust,
    shall keep you's posted.
    cheers
  1. How to REALLY shut of closed loop/ force open loop
    By Tomato in forum Gen III V8 Specific
    Last Post: June 17th, 2008, 03:37 AM
  2. Not going into closed loop
    By tblu92 in forum Gen III V8 Specific
    Last Post: February 12th, 2008, 10:22 AM
  3. closed loop and open loop switching
    Last Post: July 10th, 2006, 08:56 PM
  4. Closed Loop......Why?
    By GMPX in forum General (Petrol, Gas, Ethanol)
    Last Post: February 16th, 2006, 03:58 PM
  5. Open Loop SD VS Closed Loop SD Advantages???
    By BowlingSS in forum General (Petrol, Gas, Ethanol)
    Last Post: August 4th, 2005, 12:25 PM
Tags for this Thread
