I am looking to data log my 6L80E parameteers and the PIDs arnt supported.
I have E38/T43 ecu.
2008 LS3 Vette Supercharged
Looking to data log
Any help would be appreciated.
Also is the BBL my V2?
I have E38/T43 ecu.
Looking to data log
Confirm your software is up to date (V7.5 & V8) and that your V2 FlashScan has been programmed with the latest Bootblock and Firmware. Then program the V2 with available controllers and PIDs. See the attached thread below for information on programming controllers & PIDs ...
http://forum.efilive.com/showthread....ht=#post141499
BB = Black Box (your V2)
BBx = all Black Box functions
BBL = Black Box logging
BBF = Black Box flash
BBFF = Black Box full flash
Until you get things sorted out, I would recommend attempting "pass through" logging (using a Notebook computer connected to the V2). This may assist with trouble shooting your current issues. Once this is working to your satisfaction, move onto BBL (V2 only).
Regards,
Taz
Thanks TAZ for repling.
When I purchased it I had to update the firmware cause it wouldnt show any credits. It still says its not registered yet. trying to figure that out. I have been hooking laptop up and trying to organize the PIDs. I had some help last night with that. The above you mentioned will that help with the PIDs for the trans?
TAZ I did the above and still the PIDs in the transmission file are not supported. Anything I can try?
Also does a serial cable come with the V2 for connecting a LC-1? I didnt get one...ugh
zbadestz,
Did you update to latest V7 and V8 software from here...?
Did you update V2 firmware (comes with V8 software) to 2.07.09...?
Did you get the V7 software registered...?
Did you get the PCM/ECM/TCM licenses figured out...?
This is how to connect LC-1 to V2 (null modem): serial-port-cable-that-goes-to-v2
This is how to configure V2 BBx (look at pics):
Email sent
Questions
1 yes
2 yes
3 trying
4 need help
3. enter the details from your blue card (exactly as shown on blue card)... post screenshot.
4. after doing 1,2,3 this should sort itself out... post sceenshot.
where do I do this??
post screen shot?
I appreciate your help...I am a noob to this
Post a screenshot of theses windows:
- Help->Register EFILive
- Help->FlashScan V2 Licenses
See this thread (read posts #2 and #3): Hosting-an-Image
Use these instructions for attaching screenshots to a post:
That's ok, we're all noobs at some time or other.
