Results 1 to 1 of 1
Thread: Solenoid Issues
    Jun 2010
    Default Solenoid Issues
    I have just pulled a tune file out of car i was contacted because the car had lost drive and pulled an engine light. i haven't had a heap of experiance with tuning these and am unsure on how to advise him. The car pulled a heap of pressure control solenoid stuck on and off codes with solenoids C D and E. Would this be a tuning issue or a issue in the box. I have thought about flashing back to factory but as i didn't do the tune i don't have a factory file to support it. The cars a VE ls3 blown with a cam and a 2400 high stall with a meant to be built box. I don't no much else about the car but has been done tuned in HP so i can't read the engine but was able to pull out the box. Any advise into if i car tune this issue out would be great. Tune is attached below.
  1. 4L80-E 3/2 shift solenoid
    By ZigBlazer in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: May 18th, 2011, 06:43 PM
  2. Boost Solenoid Control w/ E38
    By JezzaB in forum E37, E38 & E67 PFI ECM's
    Last Post: March 22nd, 2011, 04:06 AM
  3. Anyone using EFI Live to control a boost solenoid???
    By spoolinsteve in forum Forced Induction and Nitrous Oxide (N20)
    Last Post: May 20th, 2010, 04:56 AM
  4. Solenoid differences
    By Cougar281 in forum Allison 5 & 6 Speed
    Last Post: February 8th, 2009, 11:52 AM
  5. EVAP vent solenoid
    By PSWired in forum General
    Last Post: June 6th, 2005, 11:03 AM
