Results 1 to 9 of 9
Thread: 4l80 swap into 1/2ton chevy pickup lockup questions
    Dec 2008
    Default 4l80 swap into 1/2ton chevy pickup lockup questions
    As title says did a 80 swap so I did a 80 full segment swap.problem I'm having is just the lockup.I can lock it up with my scanner bilateralcontroller but it won't lockup via pcm control.I've checked lockup speeds vs tps all that looks good.am I.just missing something In the segment swap.
    Aug 2010
    Is this a Gen III or Gen IV 4L80 swap ? I'm assuming it's a Gen III swap. You copied over both the 4L80 trans calibration and trans diagnostic segments ?
    Post your tune ... more eyes are often beneficial to locating issues.
    Regards,
    Taz
    Dec 2008
    Quote Originally Posted by Taz View Post
    Regards,
    Taz
    2003 silverado.yes both diag and controls entire segment swap
    Dec 2008
    Wierd part is I can make it lock up with the scan tool lol.
    Aug 2010
    Roger that. Had assumed posting in the Gen IV section of the Forum was inadvertent. I take it you are you logging GM.TCCMODE to monitor the convertor state.
    Is it the case that the PCM never locks the convertor, or inconsistently locks the convertor. Post your tune when you have the opportunity.
    Regards,
    Taz
    Post the tune, have you adjusted lockup settings?
    Dec 2008
    I just set all my shift speeds and what not,i have not adjusted any of the lockup settings,figured i wouldnt need to change to much if anything if i did a 80 seg swap.We didnt buy the adapter harness we just moved some pins around in the plug.I have input and out put speed and converter slip when i logged it so i know the input and stuff is working.When i log it it doesnt show the pcm attempting to apply the lockup.Im doing my checks in 3rd gear at 60 with 15% or so tps so it should be in lockup according to all the settings for lockup.
    Set the TCC lockup PWM tables to 90% min and 98% max, that way it will lockup faster than normal and we can see if the PCM is actually commanding lockup. Have you logged it yet? What does the TCCMODE PID say? It should go to applied when the converter locks.
    Aug 2010
    Until you post your tune we're just guessing blindly. A log of TC / trans PIDs would also be helpful.
    Regards,
    Taz
  1. 4l80 swap for custom operating system
    By uaesands in forum Custom Operating Systems
    Last Post: January 11th, 2011, 02:36 PM
  2. Ls3 swap questions
    By tor1965 in forum Conversions / Aftermarket Parts
    Last Post: July 29th, 2010, 05:05 AM
  3. e38 4l80 swap 07 silverado cant get speedo to work???
    By b18cls1 in forum E37, E38 & E67 PFI ECM's
    Last Post: July 6th, 2010, 02:45 AM
  4. Engine swap questions - Several
    By Philntx in forum Gen III V8 Specific
    Last Post: December 7th, 2008, 09:04 AM
  5. Vortec swap into 57 chevy need help
    By Spdfrk1990 in forum Vortec V6/V8 Specific
    Last Post: February 11th, 2008, 06:02 PM
