Results 1 to 4 of 4
Thread: VVT custom cam tuning
    Oct 2005
    Default VVT custom cam tuning
    We installed a custom cam in an otherwise stock L92.
    What do I need to do to get the cam dialed in? Do I need to adjust timing based
    on changes to cam phasing?
    So far there seems to be little information out there.
    Cam specs are: 218/226 .595” / .598” 114 LSA +5 advance
    Can someone guide me through this ?! I have never tuned an E38, only LS1B and Diesels
    2005 RCSB 2500HD GMC Sierra DURAMAX LLY
    1955 Chevy Truck 1st series, being restored
    2002 Mercedes C270 CDI
    E38-idle-tuning is a good place to start. Did you install a Cam Phaser Limiter Kit?
    Al
    Oct 2005
    I did install the COMP cam phaser kit.
    Oct 2005
    IIRC the guys from Comp said, lock the advance to a fixed value and tune it. Take a dyno readout.. rince and repeat. Then overlay your results and select the various advances that best suit your torque profile requirements.
    (ie) Max it out
    You probably dont want to do it in 1* increments!
    (ie) you tune it multiple times!
    2014 VF SV LS3 Maloo.
  1. E38 VVT to a E67 VVT is it possible
    By nycblazer in forum Gen IV V8 Specific
    Last Post: June 20th, 2016, 10:51 AM
  2. VVT control - limits- tuning - etc.
    By scdyne in forum General (Petrol, Gas, Ethanol)
    Last Post: December 30th, 2010, 04:58 PM
  3. B5154 VVT Cam Phaser Timing
    By MN C5 in forum Gen IV V8 Specific
    Last Post: February 13th, 2008, 09:15 AM
  4. VVT Tuning
    By Rhino79 in forum LL8 4.2L In-Line 6 - P10 PCM
    Last Post: October 24th, 2007, 01:02 PM
  5. VVT tuning proposed method
    By blandmiller in forum LL8 4.2L In-Line 6 - P10 PCM
    Last Post: May 24th, 2007, 10:05 AM
