Results 1 to 10 of 14
Thread: How to Data Log?
    Junior Member duramax07tmd's Avatar
    Feb 2010
    Default How to Data Log?
    I have searched around for a while and have not found much on a step by step on data logging. Where do I need to start with my V2 and laptop to data log? Also, how do I get the on screen gauges on my computer to work. Meaning the RPM and speedo etc..
    Thanks for any help.
    07 Chevrolet LBZ
    CCSB 4x4
    EFI Live DSP5 Duramaxtuner.com
    PPE & Aeroforce Gauges
    5" MBRP & DE Direct Pipe
    EGR Blocked & PCV Reroute
    PPE Ported Fuel Fittings
    AirDog II 165
    HD Tie Rod Sleeves
    S&B Intake
    Aug 2010
    Similar thread currently on the go that may help ...
    http://forum.efilive.com/showthread....erter-slip-pid
    You can view logged (or active) data in several ways - table, graph, or gauge type display (Dashboard). In the Scan Tool to view data in the Dashboard, press "F10". For RPM or speedometer data to be displayed, you must be actively logging (live data) or playing back a log file (saved data) where PIDs for RPM (SAE.RPM) and speed (SAE.VSS) were selected.
    Regards,
    Taz
    Quote Originally Posted by duramax07tmd View Post
    With key on, in scantool do this:
    - connect to vehicle (round green button at upper left),
    - do Files->Select Controller and select your PCM/ECM,
    - do Files->Enter VIN and enter your VIN,
    - do Info->Validate pids, wait for it to finish,
    - goto the PIDs tab and select some pids,
    - goto the Dashboard tab (goto either A or B),
    - press record (round red button at bottom center),
    you can now watch the gauges move (dash A) or the chart fill with waveforms (dash B);
    when you have logged enough, click stop (square buttton at bottom center) and save the log to file.
    Oh, see post #11 of the thread that Taz linked to in post #2 above.
    Feb 2010
    Thanks guy, much appreciated!
    07 Chevrolet LBZ
    CCSB 4x4
    AirDog II 165
    HD Tie Rod Sleeves
    S&B Intake
    Dec 2006
    nice truck!
    8.7 @ 84 (1/8 mile) bolt-ons
    Feb 2010
    I followed these steps, but after I get the dashboard up and go to the record, I do not see any button that is round or red at the bottom center to record?
    Any suggestions?
    07 Chevrolet LBZ
    CCSB 4x4
    AirDog II 165
    HD Tie Rod Sleeves
    S&B Intake
    Feb 2010
    Quote Originally Posted by Boost View Post
    nice truck!
    Thanks bud!
    07 Chevrolet LBZ
    CCSB 4x4
    AirDog II 165
    HD Tie Rod Sleeves
    S&B Intake
    Any suggestions?
    Can you post a screenshot...
    Aug 2010
    After you have the Scan Tool connected to the target controller (at the top left of the screen the "disconnect for vehicle" button should now be red - would have been grey originally), press the "F3" key to begin recording and "F4" key to stop recording. Not sure why the Start / Stop / Pause buttons are not appearing at the bottom of your screen.
    Regards,
    Taz
  1. need help VX commodore data log
    By limited cv8r in forum EFILive V4
    Last Post: March 9th, 2010, 01:39 PM
  2. I can no longer log data
    By Jasondt2001 in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: May 12th, 2009, 11:09 AM
  3. How do I post a data log?
    By 55 ss in forum Gen III V8 Specific
    Last Post: April 1st, 2009, 04:54 PM
  4. Log data freeze
    By Rusty in forum Gen III V8 Specific
    Last Post: January 20th, 2009, 07:40 AM
  5. L92 Data log
    By etmotorsports in forum Gen IV V8 Specific
    Last Post: January 26th, 2008, 04:04 PM
