Results 1 to 10 of 16
Thread: Can't do cylinder balance test. Help
    May 2011
    Default Can't do cylinder balance test. Help
    I just got my EFILive V2 scanner tool with EFILive 7.5 and v8. I got the latest update for V7.5 and V8.
    I followed the instructions to do the test. I hit F3 to start the test and it just starts recording data. There is no pop up bar graph of cylinder strength. It does nothing but start recording.
    But I can adjust RPM, fuel pressure, and I can manually turn off one injector at a time.
    No matter what I do, I can't start the cylinder balance test. What am I doing wrong?
    I have the EFILive Scan only.
    My truck: 2004 lb7
    modifications TTS Power Systems - switchable tune Economy Tow Race
    Thank You in advance for any advice.
    Oct 2009
    your wanting the injector balance rates?
    May 2011
    Well yes. I'm trying to get to this screen that is in the v7.5 scan users manual
    The user manual shows a screen from an older version of software.
    That particular screen was for the LS1 gasoline engine, it does not apply to diesel engines.
    The newer software does not yet have an automated cylinder balance test (it has a screen where you can turn off each injector while logging, i.e. manaully); there is no pop up bar graphs; I'm not sure if the injector controls in the DVT is applicable to diesel engines, I asked Tech Support about this.
    When you turn off individual injectors does your engine show any signs (rpm drops)...?
    If you're able to turn off individual injectors, then simply start logging, then turn off each injector for 3 seconds (say), do this for all injectors, then stop the log... you should see the rpm drop for each injector turned off, if the injector is bad the rpm won't drop as much.
    But, I'm not sure this is applicable to diesels.
    Apr 2008
    you can also go in to youre pids in the scan tool and select them then watch them in the data section dont forget to select diesel list of youre pids and then you will not see the gas stuff
    stock sucks
    Oct 2004
    As above you can log the balance rates via the scan tool. GM.BALRCYL1 to GM.BALRCYL8
    Andrew
    EFILive Crew
    Jun 2011
    easiest way is to go to dashboard at the top, drop down to recall factory defaults>duramax lb7/lly. then go to the tabs and click on pids. go down till u find the 8 pids for injector balance rate #1-8. double click them all. unselect about 6 pids already selected. connect, hit the yellow button at the bottom to watch data, go to data tab and look at what the injectors pids are saying.
    Junior Member O_Poole's Avatar
    Mar 2011
    Will this work ^^ the same way on a 08 LMM? Thinking i have a bad injector and would like to see some data/ balance rates.
    Thanks!
    Jun 2011
    Yes but you have to make sure you deselect a handful of pids because it will have too many channels open and won't validate the PIDS
    Mar 2011
    Thank you sir! I did get it to work and also show a code for Cly #7 let you know in a few hours!
  1. Replies: 4
    Last Post: November 29th, 2010, 02:04 PM
  2. Cylinder balance test?
    By DrX in forum General
    Last Post: April 22nd, 2006, 01:40 PM
  3. Cylinder Balance Test
    By driver456 in forum General (Petrol, Gas, Ethanol)
    Last Post: April 17th, 2006, 12:49 PM
  4. Cylinder Balance Test
    Last Post: October 11th, 2005, 04:17 PM
  5. Cylinder balance test - how to interpret it?
    By 2000ssnb in forum Tips and tricks
    Last Post: November 24th, 2003, 09:34 AM
