Results 1 to 10 of 10
Thread: 6l80 op24254909
    Apr 2008
    Unhappy 6l80 op24254909
    2010 chevy 1500 pulled tune to remove some torque managment and when i flashed back in flash failed and now stuck in 3rd gear
    stock sucks
    Apr 2008
    is this maybe because i was using version 7.5
    will it make a diffrence if i use version 8
    stock sucks
    If it failed, keep trying to flash it until it accepts a tune. Might not be this one, if it doesnt work go back to the previous tune so its at least driveable.
    Trying V8 couldnt hurt, Paul/Ross say the V8 read/write scripts are more robust than the V7.5 ones. Remember you have to save the file as a *.ctd in the V7.5 tune tool to use V8 to flash.
    Apr 2008
    keep giving me script exited with code $0548 : checksum failed please try flash procedure
    tried like 10 times now
    still not working
    thanks erik
    stock sucks
    Does your V2 have firmware 2.07.09...?
    Apr 2008
    no still on 2.07.07
    will up date now
    thanks joecar
    stock sucks
    Apr 2008
    okay updated still not working
    stock sucks
    I pm'd Tech Support.
    Oct 2004
    Their is obviously something to be looked into so please flash with V7 pass-thru for the time being.
    EDIT: We have been able to reproduce the issue so we'll be able to identify the cause.
    Andrew
    EFILive Crew
    Apr 2008
    thanks tordne
    i think this maybe a 2011 calibration the truck is a late 2010
    it went to the dealer and can at least be driven again
    stock sucks
  1. 6L80 TM removal?
    By SRT10KLLR in forum 6 speed/8 speed RWD/FWD Transmission Tuning (incl T43, T76, T87)
    Last Post: October 23rd, 2012, 06:50 PM
  2. What is Pattern A & Pattern B on the 2010 Camaro 6L80 Tranny Tune??
    By 2010 Bumblebee in forum 6 speed/8 speed RWD/FWD Transmission Tuning (incl T43, T76, T87)
    Last Post: May 5th, 2010, 09:06 PM
  3. 2010 Camaro 6L80 desired shift times
    Last Post: May 5th, 2010, 05:26 AM
  4. 6L80/90e's How they work
    By MN C5 in forum 6 speed/8 speed RWD/FWD Transmission Tuning (incl T43, T76, T87)
    Last Post: December 26th, 2008, 01:14 PM
