Results 1 to 4 of 4
Thread: Need to tune 1998 6.5Lt turbo diesel suburban
    Lifetime Member limited cv8r's Avatar
    May 2005
    Default Need to tune 1998 6.5Lt turbo diesel suburban
    Need to tune an Australian import 1998 6.5Lt turbo diesel suburban for a friend. Was wondering what software people are using or if Efilive can do the job.
    Junior Member SwedeBurb's Avatar
    Jan 2008
    TunerCat with Wester's templates... http://westersgarage.eidnet.org/programmingsoftware.htm
    /Stefan
    Mar 2009
    You may be cheaper to have HEATH do an ECM for you if it is just one that your doing. I believe HEATH sells his ECM for about $400-500 US, and the TUNERCAT package will cost about $1100 US.
    May 2005
    My friend has already gotten a Heath PCM and is fairly happy with the results, he still gets a constant MIL light and it is a pain to have to send the PCM back to the states to have changes made. What version of Tunercat is needed for this vehicle, I took the PCM apart and saw that it uses a flash chip, not eprom? Can the PCM be upgraded to a later model PCM? Are these vehicles OBDII?
    Thanks for any replies or help.
  1. GM 6.5 turbo diesel
    By great white in forum General (Diesel)
    Last Post: August 31st, 2010, 02:07 PM
  2. first diesel tune
    By pullincrazy88 in forum Duramax LB7
    Last Post: March 26th, 2010, 01:21 PM
  3. 1996 H1 Hummer Turbo-Diesel 6.5 non-intercooled
    By GAMEOVER in forum General (Diesel)
    Last Post: December 10th, 2009, 04:40 PM
  4. 02 5.3 Suburban Mileage tune.
    By SS Duramax in forum Gen III V8 Specific
    Last Post: June 22nd, 2008, 07:42 PM
  5. 01 suburban 5.3liter tune
    By newguy2diesel in forum Gen III V8 Specific
    Last Post: February 19th, 2008, 08:34 PM
