Need to tune an Australian import 1998 6.5Lt turbo diesel suburban for a friend. Was wondering what software people are using or if Efilive can do the job.
It's all good until it goes "Bang"
TunerCat with Wester's templates... http://westersgarage.eidnet.org/programmingsoftware.htm
/Stefan
You may be cheaper to have HEATH do an ECM for you if it is just one that your doing. I believe HEATH sells his ECM for about $400-500 US, and the TUNERCAT package will cost about $1100 US.
My friend has already gotten a Heath PCM and is fairly happy with the results, he still gets a constant MIL light and it is a pain to have to send the PCM back to the states to have changes made. What version of Tunercat is needed for this vehicle, I took the PCM apart and saw that it uses a flash chip, not eprom? Can the PCM be upgraded to a later model PCM? Are these vehicles OBDII?
Thanks for any replies or help.
