yeah....I think I'll just walk him through how to use LM Programer and make sure the supply voltage is
correct. I have a question tho if the low is 7.35 and the high is 22.5 why does that calc pid list the
low as 10 and the high as 20 ??
The 10 and 20 listed in the calc pid are the min/max display limits on a chart/gauge;
you can set the display limits to any values you like, I set them so that stoich is right in the middle of the chart.
If the LC-1 has the default AFR/Lambda settings you can add this to your calc_pids.txt
PHP Code:
#Units Low High Fmt Expression
*CLC-00-032
lambda 0.00 1.60 .3 "({EXT.AD1}*0.2046)+0.5"
#Code PRN SLOT Units System Description
CALC.LAMBDA_LC11 F032 CLC-00-032 lambda WO2-Analog "Wide Band Lambda 1 - LC-1"
LC-1 WBO2
