Results 1 to 10 of 17
Thread: Stock Narrowband O2's for tunning WOT
    Dec 2007
    Default Stock Narrowband O2's for tunning WOT
    I know it is not ideal but can someone post approximately what the A/F is at certain mv?
    Something like this:
    600 mv = 14 A/F
    700 mv = 13 A/F
    800 mv = 12 A/F
    900 mv = 11 A/F
    But in 50 mv increments.
    I was tuned a while back ago and just recently installed a nitrous kit. I went to the track today and tested it on a 50 shot but I did not have a wideband(I let someone borrow it and never got it back). I just want to know if I am safe to continue using it until I can hook up a wideband and/or get retuned.
    Attached is a log of a NA run and a nitrous run.
    Jul 2008
    Its a really bad idea. Sure-fire recipe for engine damage.
    The experts all weighed in on this about a week ago..Check this out:http://forum.efilive.com/showthread....nly+narrowband
    Nov 2006
    You can make a calc_pid for NBO2 mV to AFR based off WBO2.
    The one I made has a small range, 13-15 AFR.
    It does match up with WBO2 too.
    I certainly wouldn't use it for any adjustments tho.
    LC-1 WBO2
    Jul 2008
    SRT:
    In all seriousness take a look at BlackFlags nitrous log from a day or two ago:http://forum.efilive.com/showthread....l=1#post144349
    He suffered engine damage on a nitrous run. You can see he went lean, but his O2's still showed >800 mv.
    Dec 2007
    I know it is not the greatest thing to do but I do not have access to a wideband right now. Worst case scenario if the fuel solenoid was not working at all what would 50 additional hp do to my A/F if I am at 12.3 N/A without the nitrous?
    From what I have gathered it seems as the higher the mv the richer it gets. If you look at my log I went from a 840-890 range to a 900.
    Almost all nitrous companies play it safe on the jet chart and are on the rich side. Heck when we sprayed a 200 shot on the 2010 Camaro it was pig rich(low 10's high 9's) with the recommended jets. We ended up going from a 46 fuel jet down to a 33 just to get it into the 11.8 A/F range.
    I will definitely use a wideband when I begin upping the spray but for right now do you think I am safe?
    Jul 2008
    Well what I am saying is that I have seen the same 850 Mv on the narrowband equate to 11.0 or 14.0 AFR...and on the same run.
    No way I am going to tell you are safe.
    Would you really expect a good tuner to say its O.K. But, its your vehicle and you may have already determined its safe. I'm not really judging, I am just giving you my opinion.
    I like the know my WOT AFR and a wideband is the only tool to do it with.
    Good luck.
    Dec 2007
    Forget about being safe and just tell me in general is 900 mv richer or leaner than 800?
    I should have pulled the spark plugs out to check the fuel and timing but it was freaking hot yesterday(I have a sunburn to show for it) and I was being lazy.
    900mV at WOT NA (with no nitrous) is too lean... this is all that can be said about NBO2 mV.
    Your NA log indicates:
    - too lean for NA at WOT (less than 900mV and positive LTFT's),
    - intake has a restriction (6 kP drop at WOT),
    - MAF may be under-reporting (only 269 g/s at 5734 rpm WOT),
    - something wrong with your IFR (DC only gets to 35% at 5700 rpm WOT),
    - intake is pulling hot air (IAT 97°F-81°F).
    Your 50 shot log indicates (see attached pic):
    MAP drops even more, MAF is worse, IAT is too hot, IFR is wrong, HO2Sx1 is only 900mV (too lean for either NA or shot).
    50 shot at commanded 12.3 (we have no idea what actual is, but it look like it may be leaner) will cause damage... you're not safe.
    Quote Originally Posted by SRT10KLLR View Post
    900mV is still too lean for NA WOT.
    Dec 2007
    Thank you, I really appreciate it.
    Here is a little more info on my setup. It is a 2003 Silverado with a low(9:1) cr 408, cam(224/231 595/595 114) and AFR 225 heads. I am running the stock air intake with just a drop in filter, stock exhaust manifolds with just gutted cats.
    I always have high IAT's from waiting so long in the staging area before a run. I think the IAT sensor gets heat soaked.
    My stock intake could be causing the restriction.
    The tuner said my MAF was not functioning propery so he put me on a speed density tune.
    I am running 60lb(72 @58PSI) injectors that is why the IDC is so low.
    I noticed on my NA log that the O2 goes as low as 840 mv.
    I need to get a wideband hooked up and have everything checked out. The nitrous is temporary until the turbo goes on.
    What time do you want me to meet you at your house?
  1. Narrowband Interchangable?
    By LastCall in forum Gen III V8 Specific
    Last Post: May 5th, 2010, 02:18 AM
  2. checking wideband accuracy with the narrowband?
    By ryans1000 in forum General (Petrol, Gas, Ethanol)
    Last Post: December 4th, 2009, 08:59 PM
  3. tunning help
    By CPBAIT in forum Gen III V8 Specific
    Last Post: February 11th, 2007, 09:24 PM
  4. Narrowband Simulation Wiring
    By NewV in forum Gen III V8 Specific
    Last Post: January 12th, 2007, 12:53 PM
  5. Logging w/out a Narrowband...
    Last Post: December 27th, 2006, 02:33 PM
