Page 2 of 2 FirstFirst 12
Results 11 to 20 of 20
Thread: HELP! PLEASE HELP!! Truck won't start!
    Lifetime Member Max Power's Avatar
    Nov 2005
    If your stereo shuts off and turns back on when you first hit read that I don't think you'll get it to work without take the precautions above. That's what mine does to :(
    09 LMM Duramax
    Junior Member TurboBeagleBuggy's Avatar
    Dec 2005
    I can't even get the LLY in the PCM type window. i downloaded the update, but not having any luck. I can't figure out where I went wrong i saved it to the EFI Live V7 file?
    05' Silverado CC/SB
    EFI Live, PPE HOT, 285's, Isspro Gauges, Cobra 29 NWLTD w/ PA system and FireStick, toolbox, Houndsmen Deluxe dog box, and a trailer loaded with beagles that says "CAUTION FAST BEAGLES" on the back.
    Quote Originally Posted by TurboBeagleBuggy
    You have to double click on the downloaded file to run it, which will update all the EFILive files.
    Dec 2005
    all right I'll give it a try!
    05' Silverado CC/SB
    Senior Member Wasted Income's Avatar
    Dec 2005
    Got it to read just fine when I pulled the radio and onstar fuses.
    Thanks!
    -Jeff
    2005 Silverado Duramax LLY - EFI Live Tuned
    1969 Chevrolet C-10 Pickup - Turbocharged 5.3L/4L80E - EFI Live Tuned
    1975 Avenger Jet Boat - 6.0L/Berkley pump - EFI Live tune in progress
    Dec 2005
    ross do you know if you can read a tune on the duramax with a after market program in it like from hyperchips or if its best to try put the old one back in first then read it and has any one done much tuning with good power gains on the duramax i have lot of friends with them just dont wont to toast any thing trying stuff thanks
    Dec 2005
    Quote Originally Posted by 69camaro5speed
    You would be better off returning the engine to stock, then save the stock file. Once you do this, you can reinstall the Hypertech (If that is what me meant!) then you could save a file of that tune.
    If Hyperchips (?) is a plug in like the Juice, you don't need to remove it before you save the stock program. (At least this is the way I understand it!)
    You won't toast an ECM just trying to read it, worst case it will just tell you that you are locked out from attempting to read, in that case, you are stuck and will need to send the ECM back to the company that provided the tune to have it restored to stock.
  9. #19
    Quote Originally Posted by Wasted Income
    Thanks!
    -Jeff
    Jeff, are you still needing to do this?.
    I have heard if you wait about 20-30secs after turning the IGN on it can help with the onstar.
  10. #20
    Dec 2005
    I'll try it out tonight or tomorrow and let you know.
  1. help truck wont start!
    By chev in forum General (Diesel)
    Last Post: March 29th, 2010, 02:39 PM
  2. 'Race truck' wont start..
    By nonnieselman in forum Gen III V8 Specific
    Last Post: January 12th, 2010, 08:33 AM
  3. HELP 911 Cannot start truck
    By Airtime in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: September 26th, 2009, 12:08 PM
  4. MY TRUCK WON'T Start, HELP
    By ptownbacker5 in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: October 6th, 2008, 09:43 PM
  5. TRUCK WON'T START AFTER DSP5 instal
    By vortecfcar in forum General (Diesel)
    Last Post: June 8th, 2007, 05:43 AM
