I have noticed that once the filename reaches across the screen they get truncated in the V2 BBL Tune file window. If there is anyway to add the ability to scroll to view the entire filename that would be great!
Also on the same note, some info in the docs on the limitations of filenames on the V2 hardware would be good as well. I had some valid filenames on windows which would not copy to the device until they were truncated a bit.
Thanks and fantastic work on the BBL Tune. This tool just keeps getting better and better!
