Results 1 to 10 of 13
Thread: j1939 cable for Flashscan V2
    May 2009
    Default j1939 cable for Flashscan V2
    I have a customer with a school bus with an allison 2000. it is having issues and was wondering if there was a place that makes an RJ45 to j1939 cable and if it would work with the V2. or is this is even possible. From what i've read so far the only thing standing in my way is that flashscan cables are for OBD2 and the bus uses a round 9 pin ISO data connector.
    Mar 2009
    I believe you can hook an OBD2 style plug into it like it would be on a truck and read it that way. Basically you would have to make a bench harness to do it.
    Even if you do that, I doubt EFILive supports it as its not an Allison 1000 TCM...
    May 2009
    From some info i have read it is suggested all five speeds use the same TCM. I dont necessarily need to tune it just log some data with the scan tool i already own, and my favorite to use
    Ah really?! That would be good news if its indeed the case! EFILive =
    Mar 2009
    99-05 5 speed ALLISON 1000/2000/2400 all use the same TCM. There is SEVERAL different operating systems for them though, and then you throw in ALLISON customized ones into the mix as well.
    Jun 2011
    I just read an Allison2000/2400 TCM. Interesting indeed! Plugged it into my '02 chevy and saved the OS to my library. Yes they can be tuned with EFILive!
    Well, we all learned something today
    Mar 2009
    Quote Originally Posted by LReiff View Post
    FLEECE has been doing this for awhile now. He uses some custom software he has to make OS changes, then EFILIVE to make shift point changes(at least that is what he has posted in the past).
    Whats the benefit of having one? Just Curious
    04 LB7
    2010 LMM
    2015 LML
  1. Flashscan to LM-2 Serial Cable
    By TAQuickness in forum FlashScan V2 BB Logging
    Last Post: May 2nd, 2016, 10:36 AM
  2. FlashScan to LC-1 Serial Cable Diagram
    Last Post: November 26th, 2009, 07:50 AM
  3. FlashScan V2 OBDII Cable
    By minytrker in forum Purchase and Shipping
    Last Post: November 25th, 2008, 03:37 AM
  4. lly tcm j1939 messages
    By stacks04 in forum Duramax LLY
    Last Post: September 2nd, 2008, 07:24 PM
