I configured my H0159 to supply a VSS signal. On Pin 57 I do get something but I was wondering what can read this signal.
It must be a high speed signal, probably 36 pulses per output shaft revolution. I would like to feed this signal into my VSS input of an LS1B controller to convert that signal into 4k and 128k/mile signals. Will this work??!
Talked to the Dakota Digital guys but they could not confirm that their SGI-5 will work.
The only other option that comes to mind is adding a VSS and reluctor to the diff yoke to create the missing signal.
