Results 1 to 7 of 7
Thread: Camaro L99 with T43 5th/6th gear problem at 230 km/h
    Aug 2010
    Default Camaro L99 with T43 5th/6th gear problem at 230 km/h
    Hi,
    i have seen this problem now on all Camaros that we had on dyno and all customers complain about it.
    No matter if in manual or automatic mode, as soon as you get over 230 km/h (143 mph), it shifts from 6th back to 5th gear.
    Part throttle, full throttle, always.
    It is simply not possible to drive in 6th gear over 230 km/h (143 mph). You also cannot shift manually to 6th gear, it simply does not allow it.
    Does somebody see more than i see in the TCM file? I cannot see a reason why it does this.
    Note: its not a single car issue, they all do it, aslo with other TCM calibrations.
    Camaro_TCM.tun
    May 2009
    Your WOT Shift speed of 5->6 is set at 311 MPH...which ain't ever gonna happen! Might want to put it down to around 140 MPH
    Trailblazer "RS" 5.3L 6L80 4x4 & '07 TBSS LS2 6L90 AWD
    Jul 2019
    I got the same Problem....all shift points sett to correct values with BlueCat. Nothing seems to help. VSS Out limit on TCM ???
    +1 311 mph...
    a few other things:
    the mph shift tables need to be uncrossed;
    the mph wot shift points need to match the endpoints on the mph shift tables;
    the rpm shift tables need to be checked that the rpm in each gear does not conflict with the above.
    Jul 2019
    Thats for sure....
    But sometimes overlooked
    Must use a dump and change the binaries, but this time I don't have the knowledge.
    Try to figure it out in Wintertime.
    I cant believe that no one figured it out.....
    This is why:
    Quote Originally Posted by TBMSport View Post
    meaning that the WOT table should be edited down, and in the part throttle tables 5->6 should be edited down from 154+.
    All the shift tables need work, the upper end of the higher shifts spread out too much, and some the the curves cross.
    Post your tune file.
  1. Tuning A 2011 Camaro L99
    By BowlingSS in forum E37, E38 & E67 PFI ECM's
    Last Post: May 16th, 2011, 04:36 AM
  2. Reducing TM in a 2011 Camaro L99??
    Last Post: December 6th, 2010, 01:26 PM
  3. 2010 Camaro L99 vs a 2011 Camaro L99 Tune.
    Last Post: December 6th, 2010, 10:33 AM
  4. possible to unlock 6th & 7th gear on older allison?
    By rubbersidedown in forum Allison 5 & 6 Speed
    Last Post: March 18th, 2009, 04:16 PM
  5. Tranny Swap Now No Cruise Control In 6th Gear???
    By Southern Speed in forum General (Petrol, Gas, Ethanol)
    Last Post: April 25th, 2007, 03:07 PM
