I have to make a decision on which ECU to use... what is your preference.. and why?
Thanks!
Thanks!
'94 Lexus SC300 LY2 4.8, LS6 cam/springs, E38, LS3 MAF, LS2 intake, 88mm TB, 2bar MAP, T42/4L80e, mpt70
www.terratraction.com/gallery
It still depends on the rest of the vehicle, but I would go with the E38 since it had an available OS with the 4L80-E. Is going to a 24x crank reluctor out of the question?
Al
BTW running a 4L80E can be done with a 4L60E TCM OS or PCM OS, Id worry more about what ECM OS you want to run then pair an appropriate TCM OS to it. I believe you need to switch around 2 or 3 pins to make a 60E cal run a 80E.
i think this might be what you are looking for
showthread.php?13090-4l80e-4th-gear-and-tcc-problem
showthread.php?13722-Stop-TCC-unlock-when-coasting
showthread.php?13891-4L80-E-3-2-shift-solenoid
sorry i dont know how to post a link but that is the info i got from joecar
donald
thanks joecar
donald
