When I swap PCM's, does the EFIlive license follow? That is, if I have used a license on the original PCM, can I the same one on the new (swapped) PCM? (Or will I need to get another license for the new PCM?)
The old PCM will get tossed,... Do I loose the license as well?
The PCM controls the engine and trans. Will I need to use 2 licenses to do a full FLASH?
