Page 5 of 5 FirstFirst ... 345
Results 41 to 42 of 42
Thread: Newbie Here. Need some help on 09 5.3 / 6L80e and e38
  1. #41
    May 2009
    I had a customer bring a E67 controller in with a T42 transmission controller out of different vehicles. It appears the harness is done correctly except I am uncertain of the CAN wiring and associated resisters being required or not.
    I was able to pull the cal from the E67 controller however could not access the trans controller. My original thought was that if I could pull the cals I could see what they are and then full flash appropriate cals in.
    Is this idea feasible or is the inability to read the trans controller due to the 2 controllers not being paired and need to get them flashed with a Tech II. The end result is a 08 Colorado (or other similar chassis) 2.9L 4 Cyl with a 4L60 that will be turbo charged in a 39 sedan.
  2. #42
    The T42 will take (almost) whatever OS you want, just make sure the OS is compatible with the ECM OS. The ECM OS needs to match the base OS that exists already in the ECM, if you mix n match incompatible OS' you will brick the ECM.
  1. Is it possible to put the LS7 and 6L80E together
    By Brads_rs in forum Gen IV V8 Specific
    Last Post: May 17th, 2011, 02:49 AM
  2. Intro and 6L80E question
    By Goofyguy in forum 6 speed/8 speed RWD/FWD Transmission Tuning (incl T43, T76, T87)
    Last Post: February 15th, 2011, 09:43 AM
  3. 6l90e in a 6l80e car
    By b18cls1 in forum Gen IV V8 Specific
    Last Post: October 7th, 2009, 11:24 AM
  4. Need help with 6L80E/T43 tune
    By Webbs in forum 6 speed/8 speed RWD/FWD Transmission Tuning (incl T43, T76, T87)
    Last Post: January 17th, 2009, 11:27 AM
  5. Need help - L92 and 6L80E going into a 66 GTO...
    By Newguy in forum General (Petrol, Gas, Ethanol)
    Last Post: January 27th, 2008, 11:08 AM
