I need a stock file for a 2009 Pontiac G8 GT 6.0L
The pcm is locked and I'm going to buy a new one.
LC-1 WBO2
LC-1 WBO2
Auto or Manual?
Either way, swapping around E38's is a pain, make sure you get one from the right year, get the Service Number off the ECM and make sure it's a match.
I can't just upload to any E38!?
E38 serv# 12612384
I tracked down the previous owner and have come to terms with the said locking device.
Stay tuned.
LC-1 WBO2
I'm not sure if the E38 compatibility question was going for a laugh?
Have you considered sending it out to get unlocked? You could count on it being the correct ECM.
Al
The vehicle needs to stay running.
I will still need a stock file to compare to whatever PCM I use.
LC-1 WBO2
Still whatever ECM you buy unless its from an 09 G8 GT will need to be flashed with a Tech II before you can do anything with EFILive...
LC-1 WBO2
