Results 1 to 7 of 7
Thread: Typo in V8 software
    Lifetime Member limited cv8r's Avatar
    May 2005
    Default Typo in V8 software
    Is this a typo? Should this say T42 instead of T43 ?
    Attached Images Attached Images
    Aug 2010
    What V8 build are you running ?? No such typo that I can find in V8 build 151.
    Regards,
    Taz
    May 2005
    Build 151. Try looking in BBX, Tune.
    Aug 2010
    Yes sir ... BBX ... Tune ..."T42 4/5 Spd" in my V8 software ... not T43 ... not sure what the difference is between our versions of V8.
    Regards,
    Taz
    That is the field called "Caption 1" and is user settable... but I'll let Paul know just in case.
    That typo was fixed a long time ago in Options.txt. However, because the installer will not overwrite your existing Options.txt file (so you don't lose your BBx settings) it won't get corrected by installing later versions of the software.
    To get the latest Options.txt file, you'd need to delete (or rename) your existing Options.txt file and then re-install the software to force the latest Options.txt file to be installed.
    May 2005
    ok. Thanks
  1. Old Software...
    By MMLMM in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: March 19th, 2010, 07:05 PM
  2. Minor typo in the June 13th update
    By leres in forum E37, E38 & E67 PFI ECM's
    Last Post: June 14th, 2007, 05:27 PM
  3. Software Installation
    By GHamm in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: January 19th, 2007, 08:29 AM
  4. Typo?
    Last Post: October 19th, 2006, 01:03 PM
  5. Finally got my Z! Need software!!!
    By Redline Motorsports in forum General (Petrol, Gas, Ethanol)
    Last Post: March 17th, 2006, 07:26 AM
