Page 8 of 9 FirstFirst ... 6789 LastLast
Results 71 to 80 of 84
Thread: Calc.MAFT: correcting VE and calculating MAF (in single log) --> reverse of Calc.VET
  1. #71
    Quote Originally Posted by CHEVYHD496 View Post
    Ok, please go easy on me as I'm new to this! When you say "disable maf", how do I disable it? Then I do not have a WBO2, so can I then still use this setup to tune? Thanks!
    Disable the MAF by causing a MAF DTC to immediately show up...
    this can be done in any one of these ways:
    - unplug MAF if you have 3-wire connector (i.e. IAT is on separate connector).
    - edit C2901-3 to force MAF to fail.
    You may have to edit C6001 to cause P0101-3 to trigger on 1-Trip.
    If you don't have a wideband then you will only be able to correct VE for Closed Loop, i.e. low/light throttle only.
    ~ posted by phone ~
  2. #72
    Feb 2016
    Can this be done without a wideband O2 sensor?
  3. #73
    Quote Originally Posted by oreobadr View Post
    Without a wideband, you can do only CL (meaning light throttle), so you won't be able to reach high into the upper MAF table and upper VE table.
  4. #74
    Oct 2005
    In-Memory-of-Shawn-Sankey
    5. Paste-with-labels the new CALC.MAFT map into Table B5001 in your tune file:
    ( ignore this step if you're running SD, i.e. ignoring MAF and doing VE table only )
    (to limit the cell display width to something sensible, in the map properties goto the Cell tab and look at Constrain Cell Size)
    Can't find a CALC.MAFT map. What is the data in the Value column above?
  5. #75
    Quote Originally Posted by voda1 View Post
    see attached zips for maps.
    For the MAF map, the Column pid can be any pid you logged... for convenience I make it GM.MAFFREQ (same as the Row pid).
  6. #76
    Nov 2009
    Can someone please provide the necessary pids because the pictures on the first post are gone. Thanks
  7. #77
    Hmmm, I hate when PhotoBucket does that.
    Look in the calc_pids.txt file, log all the pids mentioned in there.
    There's a pdf of Calc.VET procedure here somewhere, let me find it.
  8. #78
    May 2014
    Joe, here are the 4 pics in the OP without the photobucket watermark nonsense. Use them to update the OP if you'd like and I think it would be wise to host them directly on the website so it's not reliant on an external source. I'll do the same in the VET thread.
    https://i.imgur.com/StdYwMe.png
    https://i.imgur.com/vR2YyoO.png
    https://i.imgur.com/17Ml0Ab.png
    https://i.imgur.com/wEzVfSW.png
  9. #79
    I'll look over the next few days.
  10. #80
    Nov 2009
    I'm glad you guys have the pics. I'm going over this to try to set up to tune. I finally have my WB up and running. I want tot data log now and start the process.
    Thank you!!
    Doing my best to fix what ain't broke!!
  1. Calc.VET: correcting MAF and calculating VE (in single log)
    Last Post: February 20th, 2023, 03:55 AM
  2. CALC VET Summary Notes
    Last Post: August 28th, 2014, 06:49 PM
  3. CALC. VE Table help
    By nchristian in forum Gen III V8 Specific
    Last Post: January 28th, 2011, 08:18 AM
  4. RPM Threshold for Airflow Calc {B0120}:
    By Mark300 in forum E37, E38 & E67 PFI ECM's
    Last Post: December 2nd, 2009, 12:40 PM
  5. Startup Friction Airflow Correction table?
    By jnorris in forum General (Petrol, Gas, Ethanol)
    Last Post: November 10th, 2005, 04:01 PM
