Results 1 to 3 of 3
Thread: Map readout
    Jan 2008
    Default Map readout
    Hi,just a quicky question.
    I haven't been logging for about a year on the munro and the last time i did,i noticed that the MAP guage on V4 pro default dashboard wasn't working.
    I had another play the other day and MAP is still not working.
    Been working fine for 2 years.
    All other readouts are working fine.
    If i use Tunerpro dash,map is working fine.
    Its VR V8 xml
    curious to find out why
    cheers..mario
    Can you take a short (10 second) log and send the logged data file to me at paul@efilive.com and I'll take a look.
    Hi Mario,
    The MAP sensor voltage is being sent correctly by the PCM. The sensor voltage is updating correctly as the manifold pressure changes in response to throttle inputs.
    However, the MAP sensor kPa value is NOT being sent correctly by the PCM. The kPa value is fixed at 94.38kPa.
    I cannot explain how that could happen, it doesn't make sense. Its almost like the PCM is using two MAP sensors, a working one for the voltage signal and a faulty (stuck) one for the kPa signal.
    See attached image that shows the two values' raw hex data as sent by the PCM.
    You can see the first value (the voltage) changing: 37, 37, 2C, 29, 2A ....
    You can see the second value (the kPa) fixed at EE.
    You could try logging a different vehicle using the same vehicle definition (i.e. VR V6/V8 or VS V8) and see if it exhibits the same problem.
    If the MAP kPa logs ok on a different vehicle, try replacing the MAP sensor in the current vehicle.
  1. Using V2 as a WB readout
    By turbo_bu in forum FlashScan V2 BB Logging
    Last Post: June 19th, 2009, 04:24 AM
  2. Boost VE map...............
    By FreddyG in forum Custom Operating Systems
    Last Post: October 19th, 2007, 10:21 AM
  3. Changing from a 2bar map to a 3bar map?
    By onfire in forum Forced Induction and Nitrous Oxide (N20)
    Last Post: December 23rd, 2006, 04:31 PM
  4. KR Map
    By 98WhiteDevil in forum General
    Last Post: August 12th, 2006, 01:15 PM
  5. AFR READOUT Flashscan Vs LM1
    By johnv in forum General
    Last Post: August 11th, 2005, 05:44 PM
