Done quite a bit since my initial post. yesterday I installed brand new SVO red top 30lb injectors, I set my IFR as per SSpdDmon .tun file and parameters, I also took a bunch of perimeters from his tune file and tuned some of the parameter from idle tips and tricks.
The car runs much better but occasionally stalls, this tells me i have some more tuning to do. Fuel pressure is set at 58 PSI, I stuck a camera in front of my gauge connected to the fuel rail, here are the results;
50 PSI at prime (Key On)
58 PSI running + revving to 4K
Engine off drops to 50 PSI
2 min down to 40P PSI
After about 10 min down to about 29 PSI
This is with new injectors, Porsche 944 Turbo Fuel Pump, external FPR with return.
