Page 5 of 5 FirstFirst ... 345
Results 41 to 44 of 44
Thread: LTFT (New to the forum)
  1. #41
    Jul 2008
    No, not to compensate.
    Tuning always goes better when your Trims/MAF/VE are tuned, but mechanical issues have to be solved first..
  2. #42
    Is there a way to seal the exhaust leak, either exhaust putty or aluminum foil...?
  3. #43
    May 2011
    Yes, I have sealed the drivers side header, I don't hear any leaking so I think its ok. I only had problems with the drivers side because the header was modified for the conversion, I also have my wide band in the drivers side collector and it show about a 14.5 at idle.
    What I can do is go open loop (AUTOVE) and use my LM1 in the passenger side O2 sensor position, this way I know there are no exhaust leaks. I don't think I really need to run closed loop.
  4. #44
    May 2011
    Got the car running quite well today, I modified Cranking VE + some mixture parameters and that fixed my warm start problem, the car no longer stalls after I installed and calibrated VSS. I'm preparing to do a AutoVE, I installed my LM1 in the right hand collector and it tracks very close to the LC1 in the left collector, this tells me that I either have two equal exhaust leaks or I fixed the LH exhaust leak. I copied a VE table form a tune file utilizing 333-333 cam, I'm using a 226-229, I see no LTFT above 3K but am seeing some below.
    I'm going through the AutoVE tutorial, one I get it figured out and executed I think it will fix my LTFT variances.
    I'm probably going to have to pull my tranny and get my Flywheel, PP and Clutch balanced, i have a bad vibration coming through my shifter from 2k up.
  1. New forum look
    By Chevy366 in forum Lounge
    Last Post: June 3rd, 2010, 12:42 AM
  2. New to the forum w/a question
    By fyremanpat in forum Vortec V6/V8 Specific
    Last Post: March 12th, 2010, 10:10 AM
  3. 3rd forum down under
    By eboggs_jkvl in forum Lounge
    Last Post: November 20th, 2006, 09:03 AM
  4. is the 98 forum up yet?
    By wait4me in forum General (Petrol, Gas, Ethanol)
    Last Post: January 17th, 2005, 03:46 AM
