Right on my third tune now and realised that the 15% increase was WAY to high to start with.... I have tided off the edges to a lower count and removed any dubious data for my next AutoVE config....
Question is.....can you join 2-3 plots in to one?
Reason I ask is I can use 2 or 3 journeys (to and from work/shops etc or where I have multiple stops in one journey) as useable datalogs.
Better still I would preferably like to use 2/3 BEN maps and remove the low cell counts then join the results re-averaging any duplicates as this would make the data more meaningful and useable.
It makes it easier than continually having to re-flash each log i do.... It also means that my data will be filled in more on my usual driving habits first then I can concentrate on the holes...
