Results 1 to 10 of 13
Thread: PCM bricked while
    Senior Member Chuck L.'s Avatar
    Feb 2006
    Question PCM bricked while
    driving???
    Was doing some logging for initial tuning on the 05 Hummer engine in my 55 Chevy.[Stock PCM]
    Got the cold start done, NP.
    Started the drive logging. Went WOT for a short distance, [<mi]. Got a very loud backfire and engine quit. I saved the log.
    Was fun while it lasted!!
    Will not restart, nor turn over w/ the starter. No FP prime, no ALDL connection. [Reports no vehicle found] $0280?? Tried the bench harness>> Got the same code.
    Checked all fuses. OK
    Checked for 12v to pins 20 and 57 on blu connector/good. Power is OK to the ALDL.
    I thot maybe the engine scrammed.. Appears to be OK. Plugs good, turns w/ wrench on balancer bolt, no H2O in the oil pan, etc.
    Is it usual that the PCM would just die like that?? [Only has 15K on it]
    Found some posts by TAQ back in 07.. Read and failed to "comprehend" them.
    Did a "jump" on the neutral start and FP relays. Those systems are working.
    Update:
    DFE1 and I tested the pcm w/ his bench harness. Worked fine. Found my harness was missing a ground wire connection. Corrected that. PCM worked fine.
    Tested all 12v wires to the blu connector, from Howell fuse panel. OK.
    Tested the plug in the start/run power feed. OK [Could have been flaky??] Don't know.
    Reinstalled the pcm. Previously failed systems, [neutral start & fuel pump] work.
    I have yet to start it. Am going over ALL the elec connections in the entire car....
    Thanks for listening.....
    Chuck L.
    CODY Motorsports
    Fuel Injector Service
    Madison, GA.
    706-342-3152
    770-265-5144 [C]
    Interesting, keep us posted on what you find...
    Feb 2006
    Smile
    Just completed a check of all elec devices and connections.. Found no issues.
    Rechecked the operation of the fuel and start relays, checked for fault codes,[none found], and turned the key. Engine started immediately, and began the warm up routine.
    Tomorrow, it's some drive time logging.
    A review of the run log when the backfire occurred, show the tps at 99.6% for a considerable number of frames, even tho I IMMEDIATELY got off the pedal. Tach signal did not cease immediately, either.
    I do not have fuel psi logging capability, but am planning on adding it.
    I can post the log if anyone is interested in seeing it....
    Chuck L.
    CODY Motorsports
    Madison, GA.
    706-342-3152
    770-265-5144 [C]
    Just a stab in the dark... is it possible the backfire went back out through the intake manifold and impacted the throttle? Maybe its sticking a but now? Can you check with the scanner - see if it hangs for a while after you let your foot off the pedal.
    You didn't happen to have the pedal position PID logged in that log file as well - that would tell an interesting story?
    Or can you get the freeze frame DTC data - maybe the controller saved some history data when the engine cut out.
    Feb 2006
    Default Strange....
    I haven't pulled the CAI off, but have looked at the log... Appears that the throttle was stuck @ WOT, clear up until I saved the file, and turned the key off.
    Also, the VSS never dropped, even tho the car was parked...
    Here's the log I made when the problem occurred.
    It appears you are right. The throttle never left WOT position. Time to pull the t/b off, even tho it starts and idles OK...
    NE 1 have comments?
    Thanks!
    Chuck L.
    CODY Motorsports
    Madison, GA.
    706-342-3152
    770-265-5144 [C]
    I can't explain the TP and VSS signals being pegged at those values. That is strange. One possible explanation is the PCM may have had a problem that caused it to stop transmitting the TP and VSS PID values. If the EFILive software does not get updated values for any PID(s) from the PCM it will continue to log those PIDs' current values. Some of the other PIDs' values (O2 sensors and IAT and ETC) were still updating after the RPM went to zero, so the PCM was still transmitting some rational data.
    With the engine off, and logging the throttle position, does the throttle still stick after hitting wide open throttle? Or is it behaving correctly?
    Also, does the VSS read correctly now?
    Hi Chuck,
    So you think it was that missing ground wire...?
    Log looks like PCM just hung up... SPARKADV goes to 55 (PCM reports this to V2) and shortly after WO2AFR (LC-1 reports this to V2) goes to 120... this tells me there might be a ground/power connection problem in harness and/or battery/charging system.
    TAQ had found his battery was moving under hard acceleration and shorting the terminals on the fender sheetmetal.
    Does it work right now...?
    Feb 2006
    Smile
    Hi Chuck,
    Joe/Paul...
    Thanks for the responses.
    I've checked the t/b for damage, and cycled the throttle w/ the scanner hooked up.. found no issues.
    I started it.. It lit right up, and idles fine. Am driving it today, and will log it. [This time I head TOWARD the house when I hammer it. Maybe I can coast home!]
    Joe, the grnd wire issue was on my bench harness, not on the car.
    Here's a link to LS1tech.. Someone else has reported a fp relay drop out.
    http://www.ls1tech.com/forums/pcm-di...l#post14980496
    I'm wondering if I had a fuel issue, it went lean, thus the backfire?? [FP logging is next!]
    We have added batt volts to the pid list. My batt is fresh new, had 12.6 in it when I put it in, an hr B4 the incident. It's in a plastic batt box and has no way to wiggle or short to the body.
    Only other source I may revisit, is the key switch. It's new, but?? A drop out on the on/run wire[s] could explain what happened, and why I had a "no start" after the incident..
    Again, Thanks for the help!
    Chuck L.
    CODY Motorsports
    Madison, GA.
    706-342-3152
    770-265-5144 [C]
    Feb 2006
    Question Update
    Was driving to the ft end alignment shop. Drive time was about the same as when the first failure occurred.
    At 35mph,,, WHAMO a dead player!
    Got off the street, and began a search for the cause.
    Luckily, I had left the test lite and the jumper for the start relay, in the floorboard.
    Instead of looking to the PCM, I disconnected the key sw power to the 4 fuse panel. No power, either w/ key in start or run.
    Used the jumper to get going. After the alignment, I drove back to the shop, parked the car, and went to lunch...About 1 hr, maybe 1 1/2.
    Tested for power from key sw...GOOD TO GO!
    Checked every plug, again...no problems found.
    If it was a PCM heat/failure, the power would still be there, but the PCM would have scrammed...
    My conclusion: The key switch has a heat related, intermittent failure, or???
    New sw on the way.. More later..
    Chuck L.
    CODY Motorsports
    Madison, GA.
    706-342-3152
    770-265-5144 [C]
    Did the switch get hot...?
  1. PCM Flash to Grand-AM Cup PCM
    By Rusty in forum Gen III V8 Specific
    Last Post: January 5th, 2009, 09:58 PM
  2. Replies: 6
    Last Post: November 16th, 2008, 01:49 AM
  3. Fixing your Bricked V2
    By Ira in forum FlashScan V2 BB Logging
    Last Post: April 18th, 2008, 09:21 AM
  4. 2000 truck with locked PCM, buying new PCM
    By SimpleManLance in forum General (Petrol, Gas, Ethanol)
    Last Post: January 10th, 2008, 05:06 PM
