Having a problem with a scaled tune for a Maggie TVS 1900. TBSS is perfect except for when A/C is turned on.
Smoke tested and no vacuum leak or anything. A/C off truck runs perfectly. Once A/C is turned on the airflow goes way too high and idle runs away and rpms hang and tough to even stop the truck.
I have halved B1825 and B1826 for A/C compensation and have even went to the extreme and made those -32 g/s with no change in idle.
There must be additional A/C Idle airflow tables not available to scale causing the issue.
Had to scale as to avoid maxing the maf 512 g/s limit and injector 7.9999 g/s limit
Any ideas or additional tables Ross or Paul to add to the calibration Operating System 12606494
