Results 1 to 4 of 4
Thread: Why only 24 channels when logging?
    Lifetime Member 67SS509's Avatar
    Dec 2005
    Default Why only 24 channels when logging?
    It takes me 30 channels to log what I want and seems to work ok. Instructions say not to go over 24. Why, what's the down side?
    2002 Chevy truck, SCSB 2WD, Stroked LS3 w/Big Mutha Thumper cam
    2002SS Camaro LS7/427 with stock suspension setup
    2012 Chevy truck, SCSB 2WD, Magnaflow exhaust + K&N
    Lifetime Member eboggs_jkvl's Avatar
    Apr 2004
    I think it has to do with sampling rate. The volume of data causes the rate to be slow and the data might not all display accurately.
    That would be my guess on the answer.
    Elmer
    Jun 2006
    You can logg as many as you like, but you won't get the 10 frames per second for anything over the 24 ...
    Default Fast mode frame logging
    24 channels fits into 1 frame which can be logged at 10 frame/sec; every pid is updated each frame (10 times/sec).
    25-48 channels requires 2 frames, every pid is updated every 2 frames (5 times/sec).
    49-72 channels requires 3 frames, every pid is updated every 3 frames (3.333 times/sec).
    73-96 channels requires 4 frames, every pid is updated every 4 frames (2.5 times/sec).
  1. Logging with v2
    By x MadMAX DIESEL in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: January 14th, 2010, 07:00 AM
  2. PIDs, channels for E38
    By limited cv8r in forum General
    Last Post: January 27th, 2009, 09:30 AM
  3. WB output and 24 channels for V2
    By 02Z06 in forum General
    Last Post: May 18th, 2008, 03:49 PM
  4. VE after logging
    By Beer99C5 in forum General (Petrol, Gas, Ethanol)
    Last Post: September 15th, 2006, 01:28 PM
