Results 1 to 6 of 6
Thread: Maybe two injectors bad, I isolated the worst #3 starts now. But look at what happen
    May 2011
    Angry Maybe two injectors bad, I isolated the worst #3 starts now. But look at what happen
    My truck was slowly losing power but drove OK. Then one day it wouldn't start no matter what, with out a little starting aid. So I checked the Cyl Balancing Floe Rates. I found #3 bad for sure and #6 a little weak. So I bought 2 fuel rail plugs to Isolate #3 then after that #6.
    After I installed the fuel rail plug on #3 cylinder the truck would now start on it's own again, Yeah!!! So I do another cyl balance flow rate with that number 3 rail plug/cap still on the truck. Holy crap the flow rates went south on almost all of my other injectors!!! Even the ones the were spot on.
    Please Guys give me some advice as what going on with my injectors.
    As a side note I'm checking the flow rate at normal idle and normal idle fuel pressure. Click image for larger version.
    and after I blocked injector #3
Name:	inj 3 blocked.jpg
    Thanks to everyone that helps me out on this
    May 2011
    check check
    May 2011
    here are the highlighted injector balance rate jpegs
    Attachment 10990
    Before
    Attachment 10991
    Thanks everyone!!!
    Nov 2007
    I'm assuming this is a LB7? my guess is that they are going negative to try and compensate for the dead cylinder. I would measure the fuel return on both banks and go from there. Do you have diesel in the oil?
    '04 LB7, AEM Brute Force HD Intake, 4" into 5" single stack, Kennedy Boost valve, EFILive
    May 2011
    No. My oil is ok. before I blocked cylinder number 3 I could only get 700 Psi cranking. After blocking number 3 I can get enough pressure during cranking for it to start, but the crank times are a little long. I think I will go ahead and block number 6 and see how fast it builds cranking pressure. then see if I can get my max pressure above 11,000 Psi.
    May 2011
    OH, and yes it is a 2004 LB7 with a 140K miles. this is the first fuel/injector/pump problem I have ever had with it.
  1. Changed FPR Now injectors are smoking BAD!
    By stamus25 in forum Duramax LLY
    Last Post: November 23rd, 2010, 07:06 AM
  2. What will happen?
    By ferramento in forum Allison 5 & 6 Speed
    Last Post: February 26th, 2010, 11:27 AM
  3. case grounded vs. isolated ground O2 HELP!
    By DURAtotheMAX in forum Gen III V8 Specific
    Last Post: January 4th, 2010, 07:26 PM
  4. 42lb injectors running bad
    Last Post: April 9th, 2007, 09:29 AM
